Results 1 to 3 of 3
Thread: Aero 7 theme for Windows 10 Share
    றѳѳղղįqվદ® is online now
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Đเε!
    Norway (Oslo)
    23
    2,397
    Aero 7
    Aero 7 Lite
    Aero 7 Clear
    Aero 7 Square
    for full working you need go to
    Personalize/Colors and enable Start,taskbar and action center (on)
    Katut is offline
    Jun 2014
    on Earth
    15
    3 Thread(s)
    Cheeky
    Thank you for the Visual Style it works great on Win 10 (1809)
    Just to let you know, I could not find any Extras folder in the downloaded archive, perhaps you must just check and update the files.
    Thanx again!
    Norway (Oslo)
    23
    2,397
    Quote Originally Posted by Katut View Post
    Thanx again!
    hello and because this is only windows 7 theme working on windows 10 without Extra folder
    tutorial bottom as Tools you may need and Recommended Prior to Applying Custom Themes is only info for applying custom themes
  1. Aero Gray theme for windows 7 by Mr GRIm
    By sadiq3210 in forum Theme Requests
    Last Post: 01-21-2019, 05:56 AM
  2. Aero Gray theme for windows 7
    Last Post: 08-12-2017, 07:41 AM
  3. Looking for Pro skinner to port WindowBlinds Dark Aero Glass theme to Windows 8.1.1
    By mkanet in forum Windows 8 & 8.1 Theme Help & Support
    Last Post: 12-27-2015, 03:31 PM
  4. Change default Aero theme topic for another installation of Windows 7
    By ark22 in forum General Windows 7 Customization
    Last Post: 11-29-2015, 04:41 PM
  5. anyone got a aero windows 7 basic theme
    By gondudy in forum Requests
    Last Post: 03-13-2013, 07:10 PM
