Results 1 to 4 of 4
Thread: Longhorn Inspirat SE for Windows 10 Share
    றѳѳղղįqվદ® is offline
    Ʀεαℓ Ƙɳσωℓεɖɠε Ɲεѵεг Đเε!
    Norway (Oslo)
    23
    2,387
    Longhorn Inspirat SE and SE 2 for Windows 10
    Longhorn Inspirat SE Regular Taskbar
    Longhorn Inspirat SE Thin Taskbar
    Longhorn Inspirat SE Dark Regular Taskbar
    Longhorn Inspirat SE Dark Thin Taskbar
    Longhorn Inspirat SE 2 Regular Taskbar
    Longhorn Inspirat SE 2 Thin Taskbar
    devillnside is offline
    Elite
    Aug 2012
    Dhaka, Bangladesh
    38
    1,089
    12 Thread(s)
    this looks quite nice moon, really clean
    Norway (Oslo)
    23
    2,387
    Quote Originally Posted by devillnside View Post
    yes looks simple and clean
    someone like simple and default themes as XP ,w7 aero , Longhorn or Windows Classic theme
    little free time and more requests for themes or icon packs porting but now is all ported customized and available for working on w10 RS1-RS5
    i am very glad you like it my dear friend
    Elite
    Aug 2012
    Dhaka, Bangladesh
    38
    1,089
    12 Thread(s)
    yup simplicity is the best style sometimes
  1. Replies: 0
    Last Post: 05-27-2017, 05:24 AM
  2. Longhorn Ultra
    Last Post: 10-28-2013, 12:54 AM
  3. longhorn style hacks for windows 7
    By The gimp in forum Style Hacks
    Last Post: 12-12-2009, 10:20 AM
  4. Longhorn
    By The gimp in forum Theme Requests
    Last Post: 12-12-2009, 09:56 AM
