2 Attachment(s)
Caselabs for Windows 10 Anniversary Update Redstone 1
I present to you the awesome theme by Harvey Sewdin! This one is based around CaseLabs, a well known and respected computer chassis manufacturer. I'm quite fond of their cases and decided to dedicate a theme to them. Also, I tried to make this as monochrome as possible, so any you can match any other color to the theme(or just leave it in black/white). I would like to thank JLMS2010 and Wiz766 for using their computer build/mod photos as wallpapers. Their builds and photography skills are amazing and it really matches the theme. Also, thanks to Razorsedge for pushing me into theming again, he never gave up on me. And don't forget Lamia for the amazing ports he does, thanks guys.
HOPE YOU LIKE IT :smile:
FEATURES
THEME
► CaseLabs Theme
► Cursors
► Startorb, Navigation buttons and CP side images
► Wallpapers
EXTRAS
► Adobe After Effects Splash
► Adobe Audtition Splash
► Adobe Illustrator Splash
► Adobe Photoshop Splash
► Dock Icons
► Fonts
► Rocketdock Skin
► TimeDate images
Also, check this wallpaper pack I made out if you're into PC hardware:https://virtualcustoms.net/showthread.php/68593-M-BOARDS-Walls-Collection
JLMS2010 build log: https://www.overclock.net/t/1489129/build-log-case-labs-sma8-transformation
Wiz766 build log: https://www.overclock.net/t/1536966/build-log-titan-x-ensourced-cables-caselabs-x2m/310
Information
The included Dock Icons are 48x48 in size. I found that using the native icon size in Rocketdock leaves the quality of the icons untouched. Making the Icon larger would be useless in that case, as it would shrink down. So in Rocketdock use icon size 48 for best quality.
Updated: ONE version 1.1.8.1(OldNewExplorer)
https://virtualcustoms.net/attachment...id=70715&stc=1
StartIsBack ++1.3.2
UxStyle
Works fine on RS1
Works but needs updating for RS1
Installer (32-bit+64-bit Windows)
32-bit Windows
64-bit Windows
New AeroGlass experimental builds for RS1 can be found here
Winaero tweaker
Winaero Tweaker - universal tweaker software which supports Windows 7, Windows 8, Windows 8.1 and Windows 10
Theme Install Guide can be here
