https://imageshack.us/m/534/857/infoqk.png
Seagate Desktop SSHD
Introducing Seagate Desktop Solid State Hybrid Drives
SSD Performance. HDD Capacity. Affordable Price.
SSHDs are now available for your desktop computer. Get the speed and kick of an integrated solid state drive (SSD) with the massive capacity of a desktop hard drive – all at a surprisingly low price!
- Solid state speed for fast, responsive system performance
- Up to 2 Terabytes of massive storage capacity
- Innovative use of solid state memory delivers affordable performance and capacity
- NAND Flash and HDD technology work better together to deliver improved reliability
Compare all models*Quantitative usage examples for various applications are for illustrative purposes. Actual quantities will vary based on various factors, including file size, file format, features, and application software.
https://www.seagate.com/files/www-con...ro-313x313.jpg
Solid State Drive Technology Inside Your SSHD
SSHD technology uses the right amount of ultra-fast NAND flash (the same type used in SSDs) to increase system performance. Seagate Adaptive Memory ™ technology effectively identifies the most frequently-used data and stores it in the NAND flash. The results give you greatly improved boot times, application loads and overall system responsiveness.
More about SSHD technology in FAST Storage >
https://www.seagate.com/files/www-con...ve-316x230.jpg
Get It All – Desktop Speed & Capacity.
With SSHD technology, there is no need to trade capacity for high performance. The Seagate® Desktop SSHD is available in 1TB and 2TB capacities, giving you plenty of space for all of your digital content. Store up to 1000 video games, 2000 hours of video, 500 HD DVDs, 640,000 digital photos, or over 33,000 hours of mp3 music files.*
More about SSHD storage >
https://www.seagate.com/files/www-con...-capacity.jpeg
Affordable & Reliable SSHD for Your Desktop
SSHDs fuse the strength of SSD and HDD into one affordable and powerful hybrid drive. You’ll be surprised at how little you have to pay to get SSD-like performance in your desktop system.
And since SSD fuses the strengths of both HDD and SSD technologies, you get the combined reliability of both in a solid state hybrid drive product.
Learn more about SSHD features
https://www.seagate.com/files/www-con...hd-316x230.jpg
Easy, Low-cost HDD Desktop Upgrade
SSHD provides a great way to breathe new life into an older desktop computer.
- Get performance you never thought possible from your older system
- One of the most cost-effective ways to increase the performance of your system.
- Easy, do-it-yourself upgrade solutions available
https://www.seagate.com/files/www-con...03-316x230.jpg
Seagate Adaptive Memory™ technology.
Seagate Adaptive Memory™ technology effectively identifies the most frequently-used data in your computer. This data is stored in the ultra-fast NAND flash memory which results in blazing fast boot times, and a super responsive experience where you wait less and do more. This technology is constantly working and adapting to way you work and access information.
Read more about Adaptive Memory >
https://www.seagate.com/files/www-con...s-316x230.jpeg
Solid State Hybrid Drive (SSHD) Reliability.
A typical HDD depends on moving parts and spinning media. An SSD does not have moving parts, however it’s limited by how many times data can be written to it. So, separately, each technology can have a downside. Together, they complement each other nicely. An SSHD reads primarily from SSD memory, placing less wear and tear on the HDD. Writing is achieved primarily on the HDD, helping to reduce the write-cycle wear issue.
Read more about SSHD reliability >
https://www.seagate.com/files/images/...os-316x186.jpg
SSHDs are PC & Mac compatible.
Your Seagate® Desktop SSHD is designed to work in any standard desktop system. Unlike other hybrid solutions, there are no special drivers or software to install and configure. It installs and works just like a hard drive - only faster!
Do More
https://www.seagate.com/files/www-con...th-316x120.jpg
What Is Solid State Hybrid Technology
Higher productivity, less wait time
More
Do More
https://www.seagate.com/files/www-con...de-313x120.jpg
Everything You Wanted to Know About Hard Drives
Find out what a hard drive does, how big a drive you need, and how much you can store on a hard drive
More
Do More
https://www.seagate.com/files/www-con...hd-313x120.jpg
How to Choose Between SSD, SSHD, HDD Storage for Your Laptop
HDDs offer capacity and low price. SSDs are fast. SSHDs combine the best of both HDD and SSD.
More
Do More
How to Upgrade a Desktop Hard Drive With Solid State Hybrid Drive Technology
Extend the mileage of your old desktop or get more punch out of a newer system with SSHD technology.
More
Tech Insight
https://www.seagate.com/files/www-con...de-313x120.jpgAdaptive Memory Technology in Solid State Hybrid Drives
Adaptive Memory in laptops: fast boot time and data integrity
More
Tech Insight
Solid State Hybrid Drives: Speed, Capacity and Affordability
The faster you deliver digital fuel to the microprocessor, the faster your computer performs
More
Tech Insight
Choosing High Performance Storage Is Not About RPM Anymore
Looking for performance? Solid state hybrid drives make RPM largely irrelevant as a spec
More
