1 Attachment(s)
Shotcut Free Video editor for Windows, Linux and Mac 64 bit
Hey everyone :)
I am an avid video editor I actually spend most of my time on the computer doing video editing rather then themeing believe it or not :)
I have been using the same software for quite a long time and now just before I was going to do some Christmas stuff for family and friends I thought let's see what other kind of software is out there since I had not looked for so long I normally use TMPGenc to do most of my editing needs and Sony Vegas pro as well a number of other small apps too.
Well I just found a killer Video editing application that works on all platforms Mac, Linux and Windows it comes in a 64 bit version only and it's also free dammmmm lol
This can do everything I do with many of my video editing apps all in one it's simple to use they have great tutorials that are easy the interface is great and easy it is fantastic :)
https://virtualcustoms.net/attachment...id=71624&stc=1
Features
These are all currently implemented features. See the
Roadmap for planned features.
- supports oodles of audio and video formats and codecs thanks to FFmpeg
- supports many image formats such as BMP, GIF, JPEG, PNG, SVG, TGA, TIFF as well as image sequences
- no import required - native editing
- frame-accurate seeking for many formats
- multi-format timeline: mix and match resolutions and frame rates within a project
- screen capture including background capture to capture a Shotcut session
- webcam capture
- audio capture
- network stream playback (HTTP, HLS, RTMP, RTSP, MMS, UDP)
- frei0r video generator plugins (e.g. color bars and plasma)
- Blackmagic Design SDI and HDMI for input and preview monitoring
- JACK transport sync
- deinterlacing
- detailed media properties panel
- recent files panel with search
- drag-n-drop files from file manager
- save and load trimmed clip as MLT XML file
- load and play complex MLT XML file as a clip
- audio scopes: peak meter, waveform, spectrum analyzer
- volume control
- scrubbing and transport control
- flexible UI through dock-able panels
- encode/transcode to a variety of formats and codecs thanks to FFmpeg (or libav as-built)
- capture (record) SDI, HDMI, webcam (V4L2), JACK audio, PulseAudio, IP stream, X11 screen, and Windows DirectShow devices
- stream (encode to IP) files and any capture source
- batch encoding with job control
- create, play, edit, save, load, encode, and stream MLT XML projects (with auto-save)
- unlimited undo and redo for playlist edits including a history view
- connect to Melted servers over MVCP TCP protocol
- control the transport playback of Melted units
- edit Melted playlists including suport for undo/redo
- OpenGL GPU-based image processing with 16-bit floating point linear per color component
- multi-core parallel image processing (when not using GPU and frame-dropping is disabled)
- video filters:
Blur, Color Grading, Crop, Diffusion, Glow, Invert Colors, Mirror, Old Film: Dust, Old Film: Grain, Old Film: Projector, Old Film: Scratches, Old Film: Technocolor, Opacity, Rotate, Rutt-Etra-Izer, Saturation, Sepia Tone, Sharpen, Size and Position, Stabilize, Text, Vignette, Wave, White Balance
- audio filters:
Balance, Bass & Treble, Band Pass, Compressor, Copy Channel, Delay, Downmix, Expander, Gain, High Pass, Limiter, Low Pass, Normlize, Notch, Pan, Reverb, Swap Channels
- 3-way (shadows, mids, highlights) color wheels for color correction and grading
- eye dropper tool to pick neutral color for white balancing
- UI translations: Catalan, Chinese, Czech, Danish, Dutch, English, French, German, Greek, Italian, Polish, Portugese, Russian, Slovak, Spanish (not all 100%, but you can help)
- HTML5 (sans audio and video) as video source and filters
- Leap Motion for jog/shuttle control
- DeckLink SDI keyer output
- UI themes/skins: native-OS look and custom dark and light
- control video zoom in the player: fit viewable area (default), 50%, original (100%), and 200%
- multitrack timeline with thumbnails and waveforms
- thumbnail and waveform caching between sessions
- audio mixing across all tracks
- video compositing across video tracks
- trimming on source clip player or timeline with ripple option
- append, insert, overwrite, lift, and ripple delete editing on the timeline
- 3-point editing
- hide, mute, and lock track controls
- external monitoring on an extra system display/monitor
- fade in and out audio and fade video from and to black with easy-to-use fader controls on timeline
- cross-fade audio and video dissolve transitions easily by overlapping shots on the same track of the timeline
- video wipe transitions: bar, barn door, box, clock (radial), diagonal, iris, matrix, and custom gradient image
- video quality measurement (PSNR and SSIM)
- support for 4K resolutions
