Help! Firefox 4 Tabs too high
Hi
I have a problem with the new VS i am making, tabs height in firefox is too big, As show on the picture on the left. I have tried changing the rebar and browsertabbar image height to no avail. How to make it look the way it does on the right???
Funny thing is on the right is the earlier version of the same vs that i've somehow messed :)
https://img340.imageshack.us/img340/7100/0firefox.jpg
Re: Help! Firefox 4 Tabs too high
Yeah that happens with some themes. It has something to do with the way the frame are done in the themes. Only way to fix it, that i know, is to edit the frames using Windows Style Builder
Thanks my friend :) , I tried to use the frames from the theme on the right and copied all of the properties, yet the problem persists.
I believe it has something to do with some contentmargins, probably the same that would fix that other problem i have with the glyph in VLC drop down menu as well.
Edit: Fixed it toolbar button heioght was too big. Mad it 20pix and it's fine now.
