OK well here it is, my entry for the Clash of the Titans III comp, I think this comp has been the best one yet and all the artists have really started to shine and step up their game once again in the hope to take the crown :smile:
The theme I have entered for the comp was based on a skin design I use for Messenger PLUS called Zero-G and it was the first skin I tried after installing it and I have never wanted to use another style since, the recent update of messenger however has made my old skins incompatible and that was enough to make me return to the older Messenger version so I can keep enjoying my skins lol.
I did speak to the creator asking for an update but he said he wouldn't because the new messenger plus has lost the ability to skin the frames of messenger and he said without frames it pretty much spoils the whole skin, so anyway I hope after seeing this theme he might be inspired to use it with an updated version to complete the Zero-G look again :smile:
As some of you know this style started a bit different and my original concept images had a white and black start menu and explorer windows, while I did like the look it was proving to be more difficult then I had expected trying to use the black text with a mixed Black and White theme, anyway I have recently discovered how to set the explorer window text colour using the shellstyle.dll so I will have a play with that and see if I can achieve the look I wanted without compromise.
Features:
There are 4 styles to choose from again with this theme, 2 styles with the User Picture frame in the Start Menu and 2 without, there are also Basic versions for both for those less fortunate who can not use Aero, The basic skin is fully skinned and looks almost identical and in some respects better then the Aero version so make sure even if you have Aero, especially the gamers who want to use less RAM, to check it out because I am sure you will have a pleasant surprise :smile:
Update: 14/04/2011 7tsp Extras pack Now Ready for Download, No IE mod yet as still not been able to update for IE9
Theme Includes:
:bulletgreen: ZERO-G Theme
:bulletgreen: ZERO-G Basic Theme
:bulletgreen: ZERO-G 2 Theme
:bulletgreen: ZERO-G 2 Basic Theme
:bulletgreen: MAX Glass Cursors
:bulletgreen: Fonts Eurostile
:bulletgreen: ZERO-G Sound Scheme (Thanks to Razorsedge for helping with the sounds)
:bulletgreen: Theme Resource Changer (included in theme Installer)
7tsp Theme Extras Includes:
:bulletgreen: System Clock
:bulletgreen: ieframe (IE8) Skin/Mod (coming soon)
:bulletgreen: System Properties Logo/Orb
:bulletgreen: Getting Started top Pane
:bulletgreen: Games Menu Preview Pane
:bulletgreen: New WEI index images with square borders
:bulletgreen: wmploc (Windows Media Player) Skin/Mod
Additional Extras Includes:
:bulletgreen: Zero-G Desktop Gadgets (coming soon)
:bulletgreen: Zero-G RocketDock
:bulletgreen: Zero-G ObjectDock
Theme download includes 2 installers, one for x86 and one for x64, it should be clear what one to use, the installer will not start anyway if you click on the wrong one, anyway hope you all enjoy my new theme :smile:
Mirror
Attachment 44302
Important!!
Information
If you install the theme and the start button, navigation buttons and control panel panes do not change then use this Reg fix to fix the problem, Restart explorer to take effect.
Attachment 41976
7TSP Zero-G Extras Pack
Attachment 58263
All of the other extras including WMP, Icons and any other modified system files are installed with the 7tsp extras pack using 7tsp found
For a video on how to install 7tsp extras have a look here https://virtualcustoms.net/showthread...video-tutorial
Zero-G RocketDock
Attachment 44308
Zero-G ObjectDock
Attachment 44307
Winstep Xtreme ZeroG theme by gor17981
Attachment 44313
Some Screens of the Extras
Attachment 41899
Attachment 41900
Attachment 41901
https://virtualcustoms.net/attachment...2&d=1302741224
https://virtualcustoms.net/showthread...022-Zero-G-2.0
Messenger Plus! Skin Zero-G Download
Attachment 44309
Attachment 44310
Attachment 44311
Information
Very Important!!!
UxStyle Core
Tip
Some of those using Firefox 4 may have some difficulty reading the tabs, if you do then consider Using Tab Mix Plus https://addons.mozilla.org/en-US/firefo ... -mix-plus/ I have also included the settings I have to make it easy to set up, just use the import option in settings.
Information
Added 14/05/2013: New Style Zero-G Light
Update 16/05/2013 Fixed some of the bugs in the new Light style Attachment 62921
