Intel Chipset Device Software silent installer
Author: Intel
https://www.intel.com/
License: Freeware
Requires: Win7/Vista/XP
Run this easy to use Intel® Driver Update Utility and it will "automatically" tell you if you need to update your chipset INF file, and if so, will prompt you to install and you are done. This will save you a lot of time not only on your chipset download but the most common files needed for your system.
Name changes:
Intel® Chipset Device Software is the new name for the Intel® Chipset Software Installation Utility; this name will be seen when running the installation package.
About this file/download:
The Intel® Chipset Device Software installs the Windows* INF files. An INF is a text file that provides the operating system with information about a piece of hardware on the system. In the case of the current Intel Chipset Device Software, that information is primarily the product name for the piece of hardware. This allows the operating system to show the correct name for that piece of hardware in Device Manager.
**Important**
The Intel Chipset Device Software does not install drivers for AGP or USB. DO NOT DOWNLOAD THIS UTILITY IF YOUR DEVICE MANUFACTURER IS RECOMMENDING IT TO CORRECT AN "AGP DRIVER," "AGP GART," OR "USB DRIVER" ISSUE; IT WILL NOT CORRECT YOUR ISSUE.
https://www.ryanvm.net/forum/viewtopic.php?t=9855
