5 Attachment(s)
Windows 10 Black Edition TH2
Windows 10 Black Edition TH2 November Update Only!!
Attachment 71573
RGB Color Colection
18 Styles to chose from
Enjoy!! :happy:
For November Update only!! TH2
https://virtualcustoms.net/attachment...id=70715&stc=1
StartIsBack ++1.2
- Minor changes:
UxStyle
Not currently supported fully on TH2
Attachment 71524
Use this reg file to get a Personalization Sub Menu to change themes and colors with ease, thanks to Winaero for original registry tweak https://winaero.com/download.php?view.1808.
https://virtualcustoms.net/attachment...id=70543&stc=1
Attachment 71525
Attachment 71526
https://virtualcustoms.net/attachment...id=70547&stc=1
WinAero Tweaker v3.0.2
