Attachment 78571
is this okay??
Attachment 78572
Printable View
Attachment 78571
is this okay??
Attachment 78572
perfect on small taskbar. 1 or 2 pixels low on large but barely noticeable so i say this works :peace:
Great job!
Attachment 78573
Okay,I think I am now finally plagued by the problem Dark Knight was talking about..no Windows 7 themes are importing anymore.. all throw an error.. I've tried with applying the stylehack & without applying the stylehack.. same result
Update: Actually i was doing something wrong .. got it to work again Thank God!!
Hello everyone. In case you're still wondering what this mysterious reason is for WSB throwing errors.... lmao well it is Fonts, Colors, & System Metrics > Fonts & System Metrics > Textshadowcolor. I figured this out when Razorsedge started posting new themes. Hope this helps. I just tested whether my memory was correct and deleting this single property allows the themes Noisy Boy and Friday the 13th import as expected to TH2.
Also, on a housekeeping note, I went ahead and deleted all your archive attachments in this thread.
shems right.. to be more specific.. razorsedge uses the TextshadowOffset: Position & TextshadowColor: Color properties twice. Once in:
Fonts, Colors & System Metrics > Colors (Globals)
& then in:
Fonts, Colors & System Metrics > Fonts & System Metrics
you'll find it at the very bottom.
Delete the two you find under the Fonts & System Metrics tree & you are good to go. The other two works as it should, & doesn't cause any problems.
