Yeah, I manually copied the x64 files into %SystemRoot%\system32 (as instructed) because the installers wouldn't work correctly
Printable View
I wouldn't say it's due to ONE being setup incorrectly, moreso it's actually a bug with ONE itself. I've had the white open/save dialog for quite a while now and I managed to fix it just now.
What I did was Uncheck "Enable glass on navigation bar", "Install"
Check "Enable glass on navigation bar", "Install"
And now the white bar has disappeared oddly enough and it appears correctly.
If you're refering to the letters not appearing on the properties of folders and files, then uninstalling OldNewExplorer did not help in my case. nor did re-applying it
Maybe it is part of the problem, but there's probably more to it as it didn't fix my problem :(
