TYVM I could hug you :)
I am having a problem somewhere with this. I installed everything just the way you instructed as well as set the settings. The problem I am having is that when I restart the computer I will login and right after the screen begins to flash. Then it shoots me back out into the login screen and I cant get back into my computer. I am running windows 8.1. I tried to go into safe mode but it does the same thing in safe mode as well. The only thing I could do to fix it was to restore it to factory defaults. Im not sure what info you need to help me with this problem, or if you might know what is causing it. Whatever you need to know I will gladly give though. Please help. :(
I posted once before but it isnt here for some reason... Not sure what happened. Anyway, I will post again.
I followed your instructions on installing everything as well as the settings but am running into a pretty big problem. I restart the system and it takes me to the login screen. Once I login it starts to go to the desktop but then the screen begins to flash. It flashes a few times and then it kicks me back out to the login screen. Once there it just keeps flashing and I cant log back in and get into the desktop. I tried to get in by going in to safe mode but it did the same thing in safe mode as well. I was only able to fix it by restoring computer to factory defaults. Im not sure what info is needed to help with this problem but whatever it is I will gladly post it. I would really like to get this all working so I can customize this laptop. :( Thanks
Ok, I figured out what is causing my screen to flash and whatnot. It is aero glass. I do not check either of the boxes when I install it. Once I restart the computer then that is when the problems start to occur, and there is never a water mark. I have had it install and not make the computer do that but when it seems to work ok there is never the water mark. It does sometimes show up in the list of programs though.... Please help. Thanks!
Do I not need to have aero glass installed though? As far as I can tell aero glass is not ever working correctly. Am I doing something wrong? Like I said, I dont check either of the boxes when I install it. Sometimes it makes it flash like I mentioned. In which case I have to go in and remove it cuz I cant do anything. If that doesnt happen then it just doesnt seem to be working...
I am also having one other issue that I would love to fix as well. I have HUD Red installed and the start menu is all huge and doesnt look right. Doesnt look how it is supposed to anyway. I love the look of everything but this start menu is driving me nuts. I have tried messing around with the settings in StartIsBack but whatever is causing this I cant seem to figure out. It isnt only HUD Red either. I have installed a couple other themes as well and they have all had the same problem with the start menu.
