Hello, I would like make a french version of your Se7en Theme Source patcher but i can't nor with reshacker or hex editor, is it possible to make a language file?or any way.Thanks for french user.Quote:
Originally Posted by Fixit
Printable View
i have put it on the todo list..
ill write a translation code, to use a lang.ini to translate the program it self...
but as this needs some major rewriting of all text areas in the script this could take a while..
if I can help.Quote:
tnx,
if you like you could translate the lang.ini once it is done.
first i'll have to add variables in the text areas which will then be read from the lang.ini file.
Ok , send me a private message when you want .Quote:
updated the GUI to version 0.2
~Translation code is in and so far tnx to Tytynono the English (Translate 7tsp) file for the GUI has been translated to French!
~included Explorer windows arrows for the color packs
~Added Task Manager hexing support
~Removed all folders from the internal pack (Made a Black Pack to replace these)
Regards
