i just dont know how to fix it for u, cuz after u said i downloaded from here to see if not crashed or someting like that when i ulpoaded and i got tested on 2 different virtual machines and worked fine :(
I have a feature request as well, maybe add the ability for control panel System Branding images and custom explorer background texture. I'm not sure if either of those are possible, but those are the two other ONE settings that are currently missing due to the lack of a fully working update by Tihiy.
u did all right all steps are fine, or something corrupted your system or u tried more then 1 time without restarting system and some files stuck on patch system, ill try to make new option soon for thoose who maked something wrong to fix and reset configurations to start at beggining.
your feature idea sounds good, i can add that all about branding and etc they are easiest then shell, and about ONE's i have something interesting coming. cant tell yet :)
but thats all was too much for me to do in a short period of time.
Mr GRiM is applying custom UI files the old fashioned way and modifying system files. It would be great to have those features which ONE doesn't have for sure though.
Reference this post for Mr GRiM's Experimental Theme Files
Shemhamforash you may be dealing with something like i'm currently dealing with on 10586. i installed dhjohns all-in-one installer and then to play it safe i did uxtheme and uxstyle. i added grims black themes and your special edition. i switched to grims without an issue, think i switched to yours and got the black screen and had to roll back. luckily i did a snapshot before adding yours and grims themes. still had the patchers in and tried grims themes again and black screen. from what i can see i should have no problems at all. gsw953's themes that are in dhjohns all-in-one installer work just fine.
LOL found another bug. just rightclick in the post box here to correct a word and all the text turned white.
