Aaaahh ok, recomended for me as 125% but doesnt really work unless I scale to 100% so definitely a difference there. It definitely would be different on an actual 4k monitor then.
Printable View
Thank you soooo much! i love your work, and i want ask something else about resolution my pc 4k resolution which is 3840x2160 %250 or %225 any posiblity to make it work smooth with this settings ? if yes can you help me please im trying to figure it out since 2 month :(
Good day everyone. I have two questions. Will this work on Windows 1909? When i move the MSI theme folder to themes in Resources, when i apply the theme, the only thing that changes is the wallpaper and the start menu somewhat. The shell, and most other things do not change. I get that start button to change and oldnew explorer settings to work but nothing else. Is there a more in depth tutorial or am i screwed. Thanks in advance.
hello and yes all of the 19h1 1903 themes working on 19h2 1909
and this problem is when is your system not patched first or if is your DPI Scaling higher as 100%
because more themes not supported DPI 100% - 200% 4K+ resolution
Attachment 84943
complete guide here
https://virtualcustoms.net/showthread.php/82781-Tools-needed-to-install-and-run-custom-themes
Very nice and a crisp theme (yes it hurts to say this as it is not ROG).
The red is a realy nice tone not dull or over bright just in the sweet spot, bravo young sir :applause:
