Ok i think im all lined out now. Had to download your Hud theme and make a style hack. Thanks for everything mate. :)
Thanks Grim, your instructions made everything easy peazy!
Just one thing, as always I am having trouble with the start menu after import, as you can see in the screen I have attached the bottom of the start menu is messed up, it's the only thing that I have noticed so far other than having to resize the tray flyout menu button on the taskbar that needs to be fixed. Is there a quick fix or a style hack that can take care of this or am I going to have to go in manually to fix it?
Nice job importing, like the tray flyout button,to fix the start menu you just need to install the blank font, see attached.
One other thing you should change is the content margins for the frame and the top frame image.
Windows & Caption Buttons > Aero > DWM Window > Frames > Window > Top > ContentMargins > 11, 0, 0, 0
Windows & Caption Buttons > Aero > DWM Window > Frames > Aero Peek Window > Normal > Top > ContentMargins > 11, 0, 0, 0
Great Will Try on my Next OS if its works....
Thanks Grim, that fixed the text but I still have the problem of the logoff button being out of place ..........
Does it still do it with the start menu glyph images disabled in the SiB options, looks like the places list is being stretched because of it.
Edit: Just checked and that is indeed the problem, I left a request for Tihiy to have the Glyph icons without it effecting the paces list width.
