Re: Concept Design 7tsp Theme Pack
Quote:
Originally Posted by GTK48
I installed your theme and it installed just fine using This 7tsp app. The problem I am having is when I try to install another one. The colors will bleed from one theme to the next and no matter what the 2nd theme is, the outcome is the same. I am running Windows 7 Pro 64 Bit with 8gb ram and a q6700 quad CPU. Can you only install one theme? Any help with this will be appreciated.
Sadly because 7tsp installs much more then just the theme it is really only good for installing one theme at a time, you should also uninstall previous themes before trying to install another 7tsp theme, with my themes I am now making the theme as an exe installer and I am only using 7tsp to install the icons and extras, I am also using Theme Resource Changer that is installed with the theme installer exe and that avoids having to change allot of the system files that you would normally have to edit, the good thing about that is that it also allows those changes to be applied at the same time as you select the theme, so you can select another theme at any time and it will change all the other bits that theme resource changer can do like the explorerframe, explorer and shell322 images.
Thanks Mr Grimm, that is what I thought. What would mes up were the fonts and icons. I am still using your Blue Icon Pack from long time ago. I still love it.
How come the link does not work for me?
Quote:
I added another direct link from the site, I will have to ask Fixit if he can fix the other links on his site.
Sorry.. my bad :ashamed:
link is fixed now.
Tried this Theme mostly works Except Start Orb does not change And the windows are not transparent in the slightest Apart from that all worked
I am using SP1 on windows 7 Home Premium X64
Have I done something wrong?
