Yup, you are right, that took care of it.
You don't know of anyway to change the colors of the notification icons on the taskbar next to clock? it would be nice to be able to change them from the default white instead of having to hide them.
I looked into the changing these icons:
Attachment 72350
I then found this information on the CustomizerGod website:
Quote:
Read-Only Resources
If you're using Windows 10, you may notice read-only resources in the left-hand pane. Or if you open shell32.dll in Windows 8+, it too will be loaded as read-only. This happens because the system file containing those resources is digitally signed. Modifications to the file will break the signature and Windows will refuse to load it.
This'll hopefully be circumvented in a future update to CustomizerGod.
Ported Hud Launch to Th2 but im having problems with this menu and cant figure it out. 1st off is the text is really blurry.. 2nd.. when i hover cursor over the menu hot selected doesnt work. I would appreciate any help or i could upload the msstlye if someone wants to take a look at it. Thanks
Hi Mr GRiM, I decided to get a copy of WSB. The folders work really well importing Windows 7 themes. I have a few questions for you or anyone who can answer them, hoping you could point to where they are/how to fix it. First of all control panel comes up blank with no options, how do I change this? Secondly, how do I change the caption font color? I created a style hack from equinox to try adapting that section to a theme, but as soon as I change the blue color it returns to black. Lastly where do the images go if you want custom logos in the System dialog from control panel? If I can fix those things I'll have a proper theme. :Grim:
Edit: After some time I'm no longer able to hit "Save" on a Windows 7 theme. It just crashes. I tried uninstalling and the deleting the folders and reextracting them from your archive. I wonder what could be causing this?
