So everyone gets this theme to work on his computer, and mine does not work. What a shame!
Printable View
how to fix taskbar problem:
Attachment 61166
ok im not sure if this will work for you,lol. but has in the past for me for some reason. try switching to a different theme other than these two, then log off computer and back on then try lsd again. this has worked for me in the past. other than that it may have something to do with the way you installed the theme,or the patch your using.
Hey everyone I Have an updated version of this theme pack. I fixed the top taskbar issue. Sorry I forgot to set margins for that one. I also adressed the text issue when on the web and or typing with light backgrounds. Im about to upload this new theme pack so bare with me and Ill have it to you guys in a few. As far as your troubles not being able to make the theme work please double check to make sure your sytem is patched and you have themes resource changer. You should be able to see if you have Theme Resource changer by going to installed programs. If you have both these then we will troubleshoot further. I am here for you my friend so be patient and we will Figure this out!
