Just installed that theme and it is still there. Even using the stock firefox I am having that issue. I'm going to reinstall firefox tonight and see if that fixes it.
Printable View
brilliant stuff!!! cheers for tha share
Ok Mark I wasn't forsure my bad
Casper you might try an app i have been seeing a few of the themers using called MacType https://virtualcustoms.net/showthread.php/41042-MacType it suppose to help with dark font and window boxes, I havn't tried it yet so i don't know if it would help your issue or not
Hello, really nice theme!
My main problem with the theme was that the active application is not highlighted in the taskbar but, even if I am not 100% satisfied with the graphical result, I managed to change it.
My other biggest issue is that when I receive a message in MSN, the highlight in the taskbar to notify of the incoming message is very very little. Could you tell me which file I should edit to make it more visible?
Thanks in advance!
