How do you install the skins for messenger ?
Printable View
Sir you will need to have messenger plus installed along with wlm messenger for the skin to work
https://www.msgplus.net/
Once plus is installed open messenger then double click the skin and select import in the popup menu, Once imported select the skin in the plus menu options
I would also recommend the use of this patch with wlm to shut off some of the bloat that MS forces upon us.
https://virtualcustoms.net/showthread.php/39166-A-Patch
Great job man ! :allgood: Thanks for sharing
Amazing thanks!
