Ok, let me try to apply the theme again. Hopefully it will work
UPDATE: It still does not work for me. Other themes work fine, but not this one :(
Yes, I had everything installed. Mr.Gim HUD Apocalypse is working fine
BTW, The Window Them File I extracted is only 1KB. Is it something wrong?
I tried it and it still does not work. other theme works fine :( I hope the next update may fix it for me :)Quote:
ok im not sure if this will work for you,lol. but has in the past for me for some reason. try switching to a different theme other than these two, then log off computer and back on then try lsd again. this has worked for me in the past. other than that it may have something to do with the way you installed the theme,or the patch your using.
