Everyone else here seems to be able to download and extract the file fine from VC, I myself downloaded and it extracted fine from here, it installs fine also.....sorry to say but the trouble is on the other end.
Printable View
Well not sure what you're talking about...Yes the LSD theme files - you must get 2 .theme files LSD and LSD Trans - size is 1 Kb To be correct is around 500 bytes each. It looks you downladed the file as everyone else so the problem is not there. Does the theme show in your control panel customization window - with all other themes - or not ? Oh of course you're trying to install the theme with administrator rights. Is it correct ?
deviantdon - Thanks for the tip mate
ONE MAN ARMY - thanks for the update Everything works great Well done
I have no idea what you are thinking of as far as admin rights go.
All you need to do to install this theme is extract the download to a folder,use either 7zip or winrar.
Inside the folder you just extracted too, you will find two folders one is the dock folder the other is the 2 themes folder.
Open the theme folder inside it you will see 2 more theme folders.
One is for the regular lsd theme and other is for the transparent theme.
Next open the lsd folder and you should see a Lsd.theme file and a LSD folder, drag those 2 items to c/windows/resources/themes.
Next repeat the same operation for the transparent lsd folder and drag the LSD-trans.theme file and LSD-Trans folder to same location as above c/windows/resources/themes.
Now you have install the the themes and only need to select it in your personalization menu on your desktop.
(note you must have theme resource changer installed on your system and have your system patched to run 3rd party themes)
Oh man I know that Perhaps it can be useful for Ryan_Se7en , though I think he knows as well. What I meant is that on some machines if you run a limited rights account you're not allowed to apply some changes. That's why I was asking
Ok guys. I got this theme to works now. I guess there is something wrong with my pc. I just did the clean installation, and the theme works
Special thanks to ONE MAN ARMY, deviantdon, Big V, Dark Knight. for helping me out. Thanks a lot guys
you are welcome bro,anytime.:peace:
