[SOLVED] Start button won't stay changed
I just downloaded Grim's Annihilator theme via the 7SP and everything went well. My laptop has a 18.4" inch screen with a 1920x1080 resolution I'm running win7 HP x64. For some reason the default resolution is 125% I guess because of the screen size. When I change the start orb at this resolution it changes and stays just fine. The thing is I don't like running my resolution at 125% all the time. If I put the res at anything less than 125% the start changes for a brief second, but then it just goes back to a blank spot with "menu" written in it. I think that is the default orb or start button for the Annihilator theme. I've tried just about every app or change I can think of and still no luck. I believe this has something to do with the DPI scaling but I can't be sure and that is why I'm here, so if you have an answer to my dilemma I'd greatly appreciate it.
