3 Attachment(s)
MegaMinimal green
Here is the new green theme I am currently using
I thought some of you that are using 8.1.1 might like to try it out!
Attachment 67818
Attachment 67816
It is basically an updated version of Ultimate Clean but green
and a little more minimal.I removed some of the Command Bar icons
The theme was made to be used with OldNewExplorer which can disable the Ribbon and
also allow the theme to change the white Control Panel images, plus a few more cool things.
This theme was made to be used with Aero Glass and Black Glass Enhanced. The Color Intensity is set all the way up by default so you
will have to adjust it to your desired transparency.
If you run Aero Glass you can run Taskbar Blur Toggle to get the taskbar to look like it does in the previews.
Attachment 67817
Another nice minimalistic theme from your factory Greg, thank you for sharing it with us! :peace:
Sweet one Greg... Looks awesome !!!:loving:
very nice work looks awesome.
Amazing work Greg. The Green Really looks good with this theme. Thanks
Nice style mate, good work :smile:
