this theme works on april update ?(1803)
yes bro tis theme work on w10 april update
Attachment 80580
ok thanks
Hello, just done the core install with fonts, startisback and everything with the theme but I have a little problem. No sounds play when my laptop starts up and shuts down. I've checked on the theme's properties and the sounds are there and checked to work when doing so.
I use 10 on April's update (1803) as someone already asked before me if they work and I have a Lenovo laptop. Did a new format only for this. Had the same theme on my last laptop on W7 Ultimate and everything worked fine
I don't think this is a theme issue, switch your Windows theme to the default Windows 10 theme then restart, do you get startup or shutdown sounds? I don't.
This is more than likely a Windows 10 thing, if memory serves correctly, I don't remember having any startup or shutdown sounds since Windows 7. It may have something to do with fast startup, try disabling and see if that works.
