Driver Signature Enforcement Overrider silent installer
Operation System: Windows Vista/7
Author: NGOHQ https://www.ngohq.com/home.php?page=dseo
Description: Windows Vista and Windows 7 require all drivers and system files to be signed digitally with a valid certificate or they cannot run. Pressing F8 every time on boot up can be a serious pain in the butt. Others have found workarounds, but most of them are too risky and may trash your master boot records, at least until now - thanks to our latest tool.
So how do I use it?
First and foremost; you are using this software at your own risk, we do not take responsibility for any damages to your system, but we do not believe it can harm anyone anyway. Secondly, you must run DSEO with administrative privileges (Right click and choose Run as administrator).
1. Download the application from the link below. Right click on it and choose "Run as administrator". Inside its main menu, press on the “Enable Test Mode” button and follow the instructions on the screen. This will enable TESTSIGNING mode, which allows unverified system files to be loaded.
2. Now all you have to do is to add the unverified signature to the required system files. To do so press on the “Sign a System File” button from the main menu, and enter specific filename including full path. For example: if ATITool64.sys from C:\Windows\System32\drivers refuses to load due to driver signature enforcement, you should type: “C:\Windows\System32\drivers\ATITool64.sys”, and if you would like to sign more than a single file, just repeat this procedure until you’re done, and finally reboot.
After you enabled Test Mode and added signatures to the required system files, they should bypass Windows’s driver signature enforcement and load without any issues. However, if for some reason you are interested to revert it, you can re-launch the application, choose “Disable Test Mode” from the main menu, and reboot. If you encounter issues or having questions, feel free to post it on our forums.
Note: DSEO requires administrative privileges (Run as administrator).
https://www.ryanvm.net/forum/viewtopic.php?t=9834
