2 Attachment(s)
HUD Machine Green for Windows 10 Creators Update
HUD Machine Green
Attachment 77978
Enjoy :happy:
:bulletgreen: UxTheme service hook - Visual Theme Signature Bypass
:bulletred: OldNewExplorer is the Windows 10 (and Windows 8.1, and 8) shell extension / tweaker which can undo "improvements" to file browsing made in newer Windows versions. Everything is optional for your liking.
https://virtualcustoms.net/attachment...5&d=1472576019
:bulletgreen: Full taskbar skinning!
:bulletgreen: Ability to reduce resource usage by disabling newer Start menu and Cortana processes from prelaunching
:bulletgreen: Ability to use adequately sized (32x32) large icons and larger start menu button on taskbar
:bulletgreen: Modern blur, drop shadow and immersive context menus for start menu
:bulletred: This utility returns the complete glass effect into windows frames.
:bulletred: Fully native including MSStyle themes and DWM API compatibility
:bulletgreen: Winaero Tweaker is an all-in-one application which will include most options available in the free Winaero apps and extend it as much as possible. It is a universal tweaker software which supports Windows 7, Windows 8, Windows 8.1 and Windows 10.
:bulletred: Create a Restore Point
:bulletred: Install Fonts included in the "Extras" folder
:bulletred: Apply System Metrics included in the "Extras" folder and logout or reboot
:bulletred: Install an iPack of your choice to change the system icons (check the Theme Extras section above for a link to the icons in the preview)!
:bulletred: Select the Theme's Start Menu and Taskbar in the StartIsBack++ configuration. If it's not a visible option to select the theme's start menu, apply your custom theme first!
:bulletred: Copy a Start Orb from the "Theme" folder to a new location, rename it, then open the StartIsBack++ configuration, click Add... select the Start Orb and click Apply.
