6 Attachment(s)
Make Windows 7 Welcome You With A Custom Voice Message
It’s a well-known fact that Windows 7 comes with a set of sound scheme packages and one can easily change the default sound scheme with a custom one. We also know that one can easily enable or disable the default startup sound.
Now, if you would like to make your PC welcome you with a simple voice message, we have a simple way to do that. Of course, you can go for the harder way of changing the default startup sound. But users who would like to make it simple can follow the steps given below.
1. First copy the following code in a notepad and then save the file with any name but the the file should be in .vbs extension. Of course, you can the customize the message with your own words. In this example, you can replace the words “Hello IntoWindows! Welcome back to your computer. Have a nice day” with a custom message.
Code:
Dim speaks, speech
speaks="Hello IntoWindows! Welcome back to your computer. Have a nice day"
Set speech=CreateObject("sapi.spvoice")
speech.Speak speaks
Attachment 37494
Attachment 37495
2. Now move the previously saved .vbs file to the Startup folder present in your Windows 7 drive:
C:\Users\UserName\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup
Attachment 37496
3. You are done! Simply reboot your folder to hear the cool welcome message just after the logon sound.
Thanks to Ricky and Peopleware for this info.
Re: Make Windows 7 Welcome You With A Custom Voice Message
hey thanks for this i tryed it and it worked once now when i turn on the computer it just opens it in notepad i saved it as voice.vbs and ive always put " before and after as i used to write html in note pad any help would be great
thanks 4 this info m8..gonna try it.. lol
One of the best tips i seen in a while, having lots of fun with this thanks for sharing it :cool:
Hi, I tried this and I got this error:
Windows Script Host
Script: C:\Users\Matthew\AppData\Roaming\Microsoft\Windows\Start Menu\Programs\Startup\Welcome.vbs
Line: 4
Char: 5
Error: ActiveX component can't create object
Code: 800A01AD
Source: Microsoft VBScript runtime error
OK
Can anyone help me? The only thing I changed was the message it says to my name.
