Mr GRiM
Aero-Frost-for-Windows-10-Anniversary-Update-aka-Redstone-One
Aero Frost Theme for Windows 10
Windows 10 RS2 1703 15063
Windows 10 RS3 1709 16299
Windows 10 RS4 1803 17134
Windows 10 RS5 1809 17763
Windows 10 RS6 19h1 and 20h1
dhjohns Fix for RS6 19h1 and 20h1 themes
https://virtualcustoms.net/showthread.php/19h1-Update
Windows 10 Anniversary Update Redstone 1 Only!!
https://virtualcustoms.net/Aero-Frost-for-Windows-10-Anniversary-Update-aka-Redstone-One
https://i65.tinypic.com/2l8ahyo.png
https://virtualcustoms.net/attachment...3&d=1316585287
https://virtualcustoms.net/attachment...5&d=1470536594
https://virtualcustoms.net/image/gif;...BBL4SpGCURADs= UxTheme service hook - Visual Theme Signature Bypass
https://virtualcustoms.net/image/webp...pnos8nsHxEBQ== OldNewExplorer is the Windows 10 (and Windows 8.1, and 8)
https://virtualcustoms.net/attachment...5&d=1472576019
https://virtualcustoms.net/image/gif;...BBL4SpGCURADs= Full taskbar skinning!
https://virtualcustoms.net/image/gif;...BBL4SpGCURADs= Ability to reduce resource usage by disabling newer Start menu and Cortana processes from prelaunching
https://virtualcustoms.net/image/gif;...BBL4SpGCURADs= Ability to use adequately sized (32x32) large icons and larger start menu button on taskbar
https://virtualcustoms.net/image/gif;...BBL4SpGCURADs= Modern blur, drop shadow and immersive context menus for start menu
https://virtualcustoms.net/image/webp...pnos8nsHxEBQ== This utility returns the complete glass effect into windows frames.
https://virtualcustoms.net/image/webp...pnos8nsHxEBQ== Fully native including MSStyle themes and DWM API compatibility
https://virtualcustoms.net/image/gif;...BBL4SpGCURADs= Winaero Tweaker is an all-in-one application which will include most options available in the free Winaero apps
https://virtualcustoms.net/image/webp...pnos8nsHxEBQ== Apply System Metrics included in the "Extras" folder and logout or reboot
https://virtualcustoms.net/image/webp...pnos8nsHxEBQ== Install an iPack of your choice to change the system icons (check the Theme Extras section above for a link to the icons in the preview)!
https://virtualcustoms.net/image/webp...pnos8nsHxEBQ== Select the Theme's Start Menu and Taskbar in the StartIsBack++ configuration. If it's not a visible option to select the theme's start menu, apply your custom theme first!
https://virtualcustoms.net/image/webp...pnos8nsHxEBQ== Copy a Start Orb from the "Theme" folder to a new location, rename it, then open the StartIsBack++ configuration, click Add... select the Start Orb and click Apply.
https://virtualcustoms.net/attachment...2&d=1318717506
