Alienbyte ✧☣ ДŁƗɆȠƁƳƬЄ™☣✧
Night & Day theme by ✧☣ ДŁƗɆȠƁƳƬЄ™☣✧
Rainbow Theme for Windows 10 1903/1909 19h1+
4K 5K 8K monitors need using Supported themes with DPI scaling up to 100% - 200%
Attachment 85977
https://virtualcustoms.net/attachment...3&d=1316585287
Attachment 85978
Attachment 85979
Attachment 85980
Attachment 85981
Attachment 85982
Attachment 85983
Night & Day theme TopShell
Attachment 86002
Night & Day theme BottomShell
Attachment 86003
https://virtualcustoms.net/newthread...tthread&f=1293 UxTheme service hook - Visual Theme Signature Bypass
https://virtualcustoms.net/newthread...tthread&f=1293 OldNewExplorer is the Windows 10 (and Windows 8.1, and 8)
https://virtualcustoms.net/newthread...tthread&f=1293 Full taskbar skinning!
https://virtualcustoms.net/newthread...tthread&f=1293 Ability to reduce resource usage by disabling newer Start menu and Cortana processes from prelaunching
https://virtualcustoms.net/newthread...tthread&f=1293 Ability to use adequately sized (32x32) large icons and larger start menu button on taskbar
https://virtualcustoms.net/newthread...tthread&f=1293 Modern blur, drop shadow and immersive context menus for start menu
https://virtualcustoms.net/newthread...tthread&f=1293 This utility returns the complete glass effect into windows frames.
https://virtualcustoms.net/newthread...tthread&f=1293 Fully native including MSStyle themes and DWM API compatibility
https://virtualcustoms.net/newthread...tthread&f=1293 Winaero Tweaker is an all-in-one application which will include most options available in the free Winaero apps
https://virtualcustoms.net/newthread...tthread&f=1293 Apply System Metrics included in the "Extras" folder and logout or reboot
https://virtualcustoms.net/newthread...tthread&f=1293 Install an iPack of your choice to change the system icons (check the Theme Extras section above for a link to the icons in the preview)!
https://virtualcustoms.net/newthread...tthread&f=1293 Select the Theme's Start Menu and Taskbar in the StartIsBack++ configuration. If it's not a visible option to select the theme's start menu, apply your custom theme first!
https://virtualcustoms.net/newthread...tthread&f=1293 Copy a Start Orb from the "Theme" folder to a new location, rename it, then open the StartIsBack++ configuration, click Add... select the Start Orb and click Apply.
