Thread: Ice Text
September 8th, 2009 06:21 AM #1
Ice Text
In this tutorial, i'll show you how to make your text freezing cold. This tutorial will also show you how to use this ice text on any colored background..
Start a new document 700x400px with blue HEX: #043A79 background.
Switch over to the Channel's Pallete and create a new channel. (if the channel pallete is not visible, go to "Windows » Channels".
While still in the channels pallete and with the new channel (Alpha 1) selected, select the Type Tool and type your text. Make it as big as possible.
Now duplicate this new text channel, to do this, drag the channel into the "create new channel" icon. This will not be Alpha 1 copy.
Go to Filter » Pixelate » Fragment. Repeat this step for 3 times.
Then go to Filter » pixelate » crystalize. Enter 6. (This depends on the size of your text. play around)
Go to Select » Select All, then Edit » Copy
Then go back to the layers pallete. Then Edit » Paste
Then go to Image » Adjustments » Hue/Saturation. Match the following settings:
https://www.tutorialwiz.com/tutorials/ic ... es/hue.gif
Go to Image » Rotate Canvas » 90CW
Go to Filter » Stylize » Wind
Method: Wind
Direction: From the right
Go to image » Rotate Canvas » 90CCW
Go back to the Channels Pallete. and click on the original text channel (Alpha 1) to select it.
Then go to Filter » Blur » Guassian Blur.
Enter: 8.0
Go to Image » Adjustments » Levels
Input Levels: [ 0 ] [ 0.15 ] [ 60 ]
CTRL+Click on Alpha 1 (the original text channel) to make a selection around the text.
Then go back to the Layer's Pallete
Create a new layer.
Press D and X on the keyboard to reset the colors back to default white and black.
Go to Filter » Render » Clouds
Go to Filter » Sketch » Chrome
Set:
Detail: 3
Smoothness: 3
You can play around with this to get different effects.
Apply Inner Glow layer style to this chrome layer. (Blue used: #39C5FF )
Change the blending mode of the chrome layer to overlay, and set the opacity to about 80%
Now you are done, but what if we want to place our text on another color background? we cant, because it is already on a colored background.
The following steps will show you how to overcome that.
Go back to the Channels Pallete, CTRL click on Alpha 1 to select the original text channel, then go back to the layers pallete.
Go to Select » Inverse, then hit delete to delete, then deselect.
Go to Image » Rotate Canvas » 90CW.
Go to Filter » Stylize » Wind.
Method: Wind
Go to image » rotate Canvas » 90CCW.
Now your ice text can be place on any colored background.
For more Tutorials like this go to the Tutorial WIZ
Where is this text located?
By Dark Knight in forum Start MenuReplies: 3Last Post: August 24th, 2020, 07:45 PM -
help with text
By Letícia® in forum General QuestionsReplies: 12Last Post: December 30th, 2011, 12:10 AM -
Text in rainmeter
By silverspoons in forum Rainmeter SkinsReplies: 5Last Post: January 7th, 2011, 05:37 AM -
different text color
By tony66907 in forum Text Color LocationsReplies: 18Last Post: May 13th, 2010, 01:54 PM -
Pimp your text
By Mr GRiM in forum Text Effect TutorialsReplies: 0Last Post: September 8th, 2009, 07:35 AM
Funny Mate.
Happy 4th of July
