Thread: Re: Neon Theme for Windows 7
October 14th, 2009 04:47 PM #1
I know you have waiting for it and here it is, my new Theme I called Neon, for obvious reasons I think.
A big thanks to adrianodj25 for all his hard work with this theme and my last one, without him it would not be possible for me, also a big thanks for the Wallpaper also provided by adrianodj25.
Neon Theme Download Neon.zip
New! - Updated Neon theme with some minor changes and extra features, tested on X86 and also works on X64 Neonx86.zip
InformationVery Important!!!
You must enable the use of custom themes by either patching your system with Universal Theme Patcher.
Universal Theme Patcher: https://virtualcustoms.net/showthread...s-in-Windows-7
License Agreement: This content is protected by DMCA. (Digital Millennium Copyright Act Protection Services) Last edited by Mr GRiM; February 10th, 2013 at 12:38 AM.
Neon Genesis Evangelion : MAGI SYSTEM win7 Theme
By didi49 in forum RequestsReplies: 0Last Post: December 9th, 2014, 03:30 PM -
NEON-VC
By DJ DRIVE in forum Wallpapers Posted by DJ DRIVEReplies: 3Last Post: December 5th, 2014, 01:12 PM -
WINDOWS NEON
By bigpuma in forum Wallpapers Posted by bigpumaReplies: 11Last Post: May 20th, 2013, 02:46 PM -
Neon asl ps
By sete in forum StylesReplies: 4Last Post: September 21st, 2011, 08:42 PM
Theme request
