Thread: Blue Moon Theme for Windows 7
October 26th, 2009 04:07 AM #1
New Theme called Blue Moon for Windows 7 RTM x64 and x86
Small bug with x86 in start menu, all programs button is white for some reason unknown to me.
New features of this theme include:
Taskbar support for left, right and top positioning.
New Context menus.
Removed rounded corners on explorer windows.
Removed Glow effects on Address bar and Search Bar and changed text colour to white.
New Details Pane image with resizing margins set to maintain picture aspect ratio.
All programs menu now black to match overall Start menu theme.
And a few other things that I can't remember ATM.
The icon packs and Start buttons for the themes are also there but need to be installed separately.
Blue Moon Theme Download BlueMoon.zip
Icons Pack Download https://virtualcustoms.net/forumdispl...4-Custom-Icons
Start Button Download https://virtualcustoms.net/showthread...467-Start-Orbs
To install this theme please run the Uxtheme Patcher first. https://virtualcustoms.net/showthread...er-by-SumoSoft
License Agreement: This content is protected by DMCA. (Digital Millennium Copyright Act Protection Services) Last edited by HaCkthEplAneT; August 14th, 2011 at 06:15 PM.
Alienware HQ BLUE Windows 7 Theme!
By designfjotten in forum designfjotten Window 7 ThemesReplies: 23Last Post: December 1st, 2020, 12:57 AM -
The Blue Theme for Windows 10 RS5
By gsw953 in forum Themes by gsw953Replies: 10Last Post: September 2nd, 2018, 04:02 PM -
Blue Cobalt - theme for Windows 7
By devillnside in forum devillnside's Windows 7 ThemesReplies: 4Last Post: October 21st, 2017, 03:08 AM -
MS One Blue Windows 8.1.1 Theme
By Lamia in forum Razorsedge windows 8 ThemesReplies: 11Last Post: December 5th, 2014, 11:54 AM -
https://virtualcustoms.net/showthread.php/86740-SecureUxTheme-patcher-Support-for-Windows-11
Animation in explorer...
