Thread: Different Detail Panes.
December 13th, 2009 06:52 PM #1
- Denmark
- 529
- 4 Thread(s)
Today i'ma show you how to use different detail panes on these folders:
General/Generic (Applies to all other folders than the ones listed below)
Documents
Music
Photo + Video (Same image on both)
First off download the attached ZIP file.
When that is done, apply the stylehack to WSB.
Then we come to the shellstyle.dll
For this you will need a theme folder + theme file (as the ones in the Themes folder aka a finished theme ready to install (includes folder + theme file))
Replace the shellstyle.dll in the Shell -> Normalcolor folder.
Now to make the different panes
Make some different panes, max 4 different can be used.
Apply them here: Explorer & Shell -> Shell -> Previewpane
Now change these as you wish and save the msstyles file
To see these changes (the panes) you will need to install the theme (with folder and theme file).
When you've put those into the themes folder, and made sure the name on all elements are right and that/if you did changes in the theme file (paths and names) that it is applied to the elements where it is nessacery.
Now go to personalization and select the theme.
Now voila you should have different detail panesLast edited by bgjerlow designs; August 26th, 2011 at 12:24 PM.
Help, Detail pane won't show up
By bellamysan in forum Explorer and shellReplies: 16Last Post: May 15th, 2014, 02:32 PM -
How to remove bar under detail pane ?
By pats in forum General QuestionsReplies: 3Last Post: April 12th, 2013, 06:07 PM -
close button disappears on basic panes
By King Moeha in forum Windows and caption buttonsReplies: 7Last Post: June 16th, 2012, 10:01 AM -
Random Panes
By Psych0t1c in forum Windows 7 Theme Help & SupportReplies: 18Last Post: September 17th, 2011, 05:00 PM -
Move Cont Panel Panes 2 Right by ~leepat0302
By razorsedge in forum MiscellaneousReplies: 0Last Post: November 5th, 2010, 04:30 AM
Funny Mate.
Happy 4th of July
