Thread: Animated txt in windows 7 Theme
July 29th, 2010 01:12 AM #1
Animated txt in windows 7 style
How to add animated txt to shellstyle.dll for your theme
As most of you know with windows 7 and the details pane you have the information for the file you click on show there
With these few style edits in the shellstyle.dll of your theme you can animate the txt that is shown in this pane
so first go to your theme folder and then into the shell folder then into the normal color folder and open the shellstyle.dll in restorator
once open in restorator click on the UIFILE folder
then inside on the 1.txt
now at the top of restorator click the RC button and then the ab button this will allow you to be able to edit the txt in the file
now there are different effects you can add I like the expand txt but you can use others the codes for the different effects are as follows
- (if you choose the "expand" animation):
Code:<element id="atom(animation)" animation="rectangle|exp|fast"/>
Code:<element id="atom(animation)" accessible="true" alpha="0" animation="alpha|s|veryslow"/>
Code:<element id="atom(animation)" animation="position|exp|fast"/>
Code:<element id="atom(animation)" animation="rectanglev|exp|fast"/>
Code:<element id="atom(animation)" animation="rectangleh|exp|fast"/>
to see what the different sffects do watch these vids
Code:https://www.youtube.com/watch?v=7N2pLm3wEww
Code:https://www.youtube.com/watch?v=cFvZLkKbUdI
<MetadataElement ThemeSubApp="DocumentsPreviewPaneControl" />
<element id="atom(animation)" animation="rectangle|exp|fast"/>NaN
<MetadataLabel foreground="themeable(gtc(PreviewPane, 6, 0, 3803), windowtext)" /> <MetadataElement foreground="themeable(gtc(PreviewPane, 7, 1, 3803), windowtext)" /> <if id="atom(PreviewMetadataControlEditable)"><MetadataDisplayElement foreground="themeable(gtc(PreviewPane, 7, 2, 3803), windowtext)" /></if> <if id="atom(PreviewMetadataEditControl)"> <InPlaceEdit foreground="themeable(gtc(PreviewPane, 7, 2, 3803), windowtext)" /></if> <if id="atom(PreviewMetadataSubTitleControl)"><MetadataElement foreground="themeable(gtc(PreviewPane, 6, 0, 3803), windowtext)" /></if> <if id="atom(PreviewMetadataTitleControl)"> <MetadataElement foreground="themeable(gtc(PreviewPane, 5, 0, 3803), windowtext)" /></if> <if id="atom(ItemCountLabel)"> <MetadataLabel foreground="themeable(gtc(PreviewPane, 7, 1, 3803), windowtext)" /></if> <PreviewMetadata padding="Rect(10rp, 5rp, 10rp, 3rp)" /> <MetadataDisplayElement contentalign="bottomleft | endellipsis" /> <if id="atom(PreviewMetadataRow)"> <Element height="18rp" /> </if> <if id="atom(PreviewMetadataControlEditable)"> <MetadataDisplayElement cursor="ibeam" /> <if KeyFocused="true"> <MetadataDisplayElement contentalign="focusrect | bottomleft | endellipsis" /> </if> </if> <if id="atom(PreviewMetadataEditControl)"> <InplaceEdit contentalign="bottomleft | endellipsis"/> </if> <if id="atom(PreviewMetadataReadOnlyControl)"> <InplaceEdit contentalign="bottomleft | endellipsis"/> </if> <if id="atom(PreviewForceLoadMetadata)"> <Button background="themeable(dtb(PreviewPane, 2, 1), ARGB(0, 0, 0, 0))" foreground="gtc(FlyoutStyle, 3, 3, 3803)" cursor="hand" contentalign="bottomleft" font="gtf(TEXTSTYLE, 4, 0)" height="18rp" /> <if MouseFocused="true"> <Button background="themeable(dtb(PreviewPane, 2, 2), ARGB(0, 0, 0, 0))" /> </if> <if KeyFocused="true"> <Button contentalign="focusrect | bottomleft" /> </if> </if> <PreviewThumbnail padding="Rect(18rp, 4rp, 4rp, 4rp)" background="ARGB(0, 0, 0, 0)" /> <if id="atom(PreviewMetadataTitleControl)"> <MetadataElement font="menufont;110%" height="18rp" /> </if> <if id="atom(PreviewMetadataSubTitleControl)"> <MetadataElement font="gtf(TEXTSTYLE, 4, 0)" height="18rp" /> </if> <if id="atom(PreviewMetadataControl)"> <MetadataElement font="gtf(TEXTSTYLE, 4, 0)" contentalign="bottomleft | endellipsis" /> </if> <if id="atom(ItemCountLabel)"> <MetadataLabel font="menufont;110%" contentalign="bottomleft | endellipsis" height="18rp" /> </if> <if id="atom(PreviewMetadataSpacer)"> <Element height="18rp" /> </if> <if id="atom(PreviewEditMetadata)"> <Element height="18rp" /> </if> <MetadataLabel padding="Rect(0rp, 0rp, 3rp, 0rp)" font="gtf(TEXTSTYLE, 4, 0)" contentalign="bottomright | endellipsis" height="18rp" />
<MetadataElement ThemeSubApp="GenericPreviewPaneControl" />
<if id="atom(clientviewhost)">
<ViewHost
foreground="windowtext"
background="themeable(gtc(ItemsView, 0, 0, 3802), window)"
sortcolumn="themeable(gtc(ItemsView, 0, 0, 3802), window)"
subtext="ARGB(255, 139, 139, 139)"
</if>
<Sizer background="ARGB(0, 0, 0, 0)" /> <if SlidesUpAndDown="true"> <Sizer height="5rp" cursor="sizens" /> </if> <if SlidesUpAndDown="false"> <Sizer width="3rp" cursor="sizewe" /> </if> <if id="atom(PreviewPaneSizer)"> <Sizer background="themeable(ARGB(0, 0, 0, 0), buttonface)" /> </if> <if id="atom(PageSpaceControlSizer)"> <Sizer background="themeable(dtb(PreviewPane, 3, 0), buttonface)" borderthickness="rect(0rp,0rp,0rp,0rp)" /> </if> <if id="atom(ReadingPaneSizer)"> <Sizer background="themeable(dtb(PreviewPane, 4, 0), buttonface)" borderthickness="rect(0rp,0rp,0rp,0rp)" /> </if> <if id="atom(ProperTreeExpandoSizer)"><Sizer background="buttonface" bordercolor="buttonhighlight" borderstyle="solid" borderthickness="rect(0rp,1rp,0rp,1rp)" height="4rp" /> </if> <if id="atom(PreviewPaneSizer)"> <Sizer InitialSize="53" MinSize="53" ReservedSpace="170" FramePersistType="2" /> </if> <if id="atom(CommonItemDialogSizer)"> <Sizer InitialSize="100" MinSize="100" FramePersistType="2" /> </if> <if id="atom(PageSpaceControlSizer)"> <Sizer InitialSize="160" MinSize="60" ReservedSpace="132" FramePersistType="2" ReservedMaster="atom(ReadingPane)" /> </if> <if id="atom(ProperTreeExpandoSizer)"><Sizer InitialSize="120" ReservedSpace="26" FramePersistType="2" InitialMaxxedOut="true" /> </if> <if id="atom(PreviewPaneSizer)"> <Sizer ExplorerVisibility="{43abf98b-89b8-472d-b9ce-e69b8229f019}" DisablingPolicy="{17067f8d-981b-42c5-98f8-5bc016d4b073}"/> </if> <if id="atom(ReadingPaneSizer)"> <Sizer ExplorerVisibility="{893c63d1-45c8-4d17-be19-223be71be365}" DisablingPolicy="{33dcce8d-b6f8-4b7a-ac93-45e301f956aa}" /> </if> <if id="atom(PageSpaceControlSizer)"> <Sizer ExplorerVisibility="{cb316b22-25f7-42b8-8a09-540d23a43c2f}" /> </if> <if id="atom(ReadingPaneSizer)"> <Sizer InitialSize="260" MinSize="68" ReservedSpace="202" GrowTargetFirst="true" ReservedMaster="atom(PageSpaceControlSizer)" FramePersistType="3" InitialVisibility="false" /> </if>
<TemplateBackground background="ARGB(0, 0, 0, 0)" /> <if id="atom(ReadingPane)"><TemplateBackground background="themeable(Gradient(gtc(ReadingPane, 1, 0, 3810), gtc(ReadingPane, 1, 0, 3811), gtc(ReadingPane, 1, 0, 3812), 4), window)" font="gtf(TextStyle, 4, 0)" /></if> <if id="atom(RPaneCoverSheet_NoSel)"><Element foreground="themeable(gtc(ReadingPane, 2, 0, 3803), windowtext)" background="ARGB(0, 0, 0, 0)" /> </if>
<if id="atom(PreviewShineLayer)"> <TemplateBackground background="themeable(dtb(PreviewPane, 1, 1), window)" /> </if> <if Vertical="true" id="atom(PreviewShineLayer)"> <TemplateBackground background="themeable(dtb(PreviewPane, 1, 2), window)" /></if>
</style>
<style resid="musiclayoutstyle">
<if id="atom(PreviewContainer)">
<Element
padding="rect(10rp, 8rp, 8rp, 8rp)"
</if>
<Element
padding="rect(4rp, 4rp, 4rp, 4rp)"
</if>
<MetadataElement ThemeSubApp="MusicPreviewPaneControl" />
<ViewHost
</if>
</style>
<style resid="photolayoutstyle">
<Element
</if>
<Element
</if>
<MetadataElement ThemeSubApp="PhotoPreviewPaneControl" />
<ViewHost
as you can see the 4 spots for them are you just add the txt after the metdataelement themesubapp line in each case
Code:MetadataElement ThemeSubApp="DocumentsPreviewPaneControl" /> <element id="atom(animation)" animation="rectangle|exp|fast"/>
Code:<MetadataElement ThemeSubApp="MusicPreviewPaneControl" /> <element id="atom(animation)" animation="rectangle|exp|fast"/>
Code:<MetadataElement ThemeSubApp="GenericPreviewPaneControl" /> <element id="atom(animation)" animation="rectangle|exp|fast"/>
Code:<MetadataElement ThemeSubApp="PhotoPreviewPaneControl" /> <element id="atom(animation)" animation="rectangle|exp|fast"/>
thanks to rajtheban95 for his tut and psych0t1c for the shellstyle info
ewPaneControl" />
Ultimate Edition Animated Cursor Pack by Shemhamforash for Windows
By razorsedge in forum CursorsReplies: 15Last Post: April 16th, 2022, 03:17 AM -
HUD Chrome Theme Animated
By 8pecxstudios in forum MiscellaneousReplies: 26Last Post: February 13th, 2018, 09:34 PM -
Animated Cursor Theme Collection
By Shemhamforash in forum Linux CursorsReplies: 1Last Post: August 25th, 2017, 12:49 PM -
animated sig
By The Archiver in forum Other DesignsReplies: 8Last Post: May 31st, 2012, 12:22 PM
Miscellaneous Music...
