July 29th, 2010 06:22 AM #1
How to uninstall programs in Windows Safe Mode
Sometimes programs may not uninstall in the regular mode correctly, and you may at times have to boot in safe mode to uninstall software.
However, Windows Installer will not work under Safe Mode, this means that programs cannot be installed or uninstalled in safe mode without giving a specific command using msiexec in command prompt.
To make Windows Installer to work under Safe Mode you need to create registry entries. To know how to do it manually, click : How to make Windows Installer work in Safe Mode.
Windows installer will not work under Safe Mode, this means that programs cannot be installed or uninstalled in safe mode without giving a specific command using msiexec in command prompt.
To make windows installer to work under safe mode you need to create a registry entry for every type of safe mode you are login into:
Safe Mode:
Type this in a command prompt:
REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Minimal\ MSIServer"/VE/T REG_SZ /F/D"Service"
Then start the Windows Installer service by typing net start msiserver
Safe Mode with Network:
REG ADD "HKLM\SYSTEM\CurrentControlSet\Control\SafeBoot\Network\ MSIServer"/VE/T REG_SZ/F/D"Service"
Then start the Windows Installer service by typing net start msiserver.
Alternatively, you can also download and use this freeware utility which automates the entire process and makes thing easier for you.
Simply download SafeMSI, boot in safe mode and then run this utility.
Attachment 34353
https://www.windowsitpro.com/content/...87/SafeMSI.zipLast edited by Big V; August 12th, 2011 at 04:48 AM.
Windows 10 Dark mode mode Ribbon
By ceo54 in forum Windows 10 Theme Help and SupportReplies: 6Last Post: March 1st, 2021, 05:07 PM -
How to tell if Windows 8.1 runs in UEFI mode or in the Legacy BIOS mode
By Originalganjaman in forum General TutorialsReplies: 0Last Post: February 3rd, 2014, 12:34 PM -
how to fix icons after theme uninstall in windows 7 and 8 new way
By polterghozt in forum General Windows 7 CustomizationReplies: 3Last Post: July 8th, 2013, 04:26 AM -
How to start Microsoft Word 2010 in Safe Mode
By razorsedge in forum News & ReviewsReplies: 0Last Post: September 16th, 2010, 09:37 PM
Lightstar Can Be Very Protective Of His Creations As He Sends A Percentage Of Funds Made To Charities For The Poor, Best To Take This To PMs. As Its Premium, You Could Say "Inspired By" Or Something...
Theme request
