July 29th, 2010 07:09 AM #1
Fix: The User Profile Service failed the logon. User profile
If you are unable to log on to your Windows 7 or Vista computer by using a temporary user profile, then this article may interest you.
msfixit Fix: The User Profile Service failed the logon. User profile cannot be loaded
When this happens, you will usually get the following error message:
The User Profile Service failed the logon. User profile cannot be loaded.
This issue may occur if the user profile was manually deleted by using the command prompt or by using Windows Explorer and if the “Do not logon users with temporary profiles” Group Policy setting is configured.
A profile that is manually deleted does not remove the security identifier (SID) from the profile list in the registry.
If the SID is present, Windows will try to load the profile by using the ProfileImagePath that points to a nonexistent path. Therefore, the profile cannot be loaded.
To resolve this problem open yourself, follow these steps:
Right click Computer > Properties > Advanced system settings > Advanced tab > Under User Profiles, click Settings > In the User Profiles dialog box, select the profile that you want to delete > click Delete > Apply/OK.
Next open regedit and navigate to the following key:
HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\Windows NT\CurrentVersion\ProfileList
Right-click the SID that you want to remove, and then click Delete.
Log on to the computer and create a new profile.
Alternatively, you can simply download and use this Fix It 50446 from Microsoft given on KB947215.
https://support.microsoft.com/kb/947215
[HELP!] Corrupt Windows 10 user profile by using an old theme!
By MatthewPatel in forum Windows 10 Theme Help and SupportReplies: 6Last Post: February 28th, 2019, 08:19 PM -
Possible to change logon screen user frame and font ?
By Dicehunter in forum General Windows 7 CustomizationReplies: 4Last Post: November 21st, 2013, 02:53 PM -
Windows Live Profile Notes and Private Messages service disc
By razorsedge in forum News & ReviewsReplies: 0Last Post: April 25th, 2011, 11:48 PM -
By razorsedge in forum News & ReviewsReplies: 0Last Post: February 13th, 2011, 03:53 AM -
How To Prevent A User From Changing Logon Password In Window
By razorsedge in forum Setup TutorialsReplies: 0Last Post: September 8th, 2010, 12:44 AM
Thanks so much :)
Customize icon
