Results 1 to 2 of 2
Thread: Process Lasso silent installers
August 1st, 2010 06:06 AM #1
Attachment 34486
Process Lasso is a unique new technology that will improve your PC's responsiveness and stability during periods of high CPU load. Windows, by design, allows programs to monopolize your CPU without restraint -- leading to freezes, hangs, and micro-lags. Process Lasso's ProBalance (Process Balance) technology intelligently adjusts the priorities of running programs so that badly behaved processes won't negatively impact the responsiveness of your PC.
Process Lasso also offers an assortment of ways to take full control of how your CPUs are allocated to running programs. In essence, it is an all-in-one automated Windows process tuner. You can choose at what priority processes should run, and which CPUs should be assigned to them. You can also disallow certain programs from running, log all programs run, automatically restart programs, limit the number of instances of a program, and much more. You can even indicate processes that should induce entrance into the High Performance power scheme or prevent the PC from sleeping. A gaming mode also allows for easy process priority optimization for avid gamers.
As an aside, in Windows Vista and Windows 7, adjustments of the process priority class also have an effect on the I/O and SuperFetch memory priorities for that process.
Once you install Process Lasso, it will just start working. More advanced users can tweak the configuration, but you needn't touch anything to have it instantly improve your system responsiveness and prevent stalls in high load situations.
Process Lasso is very useful and effective on even the latest high-end PCs. However, its ProBalance algorithm achieves maximum effect on PCs with relatively little CPU 'power', such as Netbooks, Tablets, and older desktops.
Process Lasso runs on all editions of Windows 2000, XP, 2003, 2008, Vista, and Windows 7.
* ProBalance dynamic priority optimization
* Works great for Desktops, Laptops, Tablets, and Netbooks
* When CPU hungry background processes are affecting responsiveness, ProBalance can:
o Lower the offending process's priority class until it quiets down
o Change the offending process's CPU affinity
* When specified processes are run, Process Lasso can:
o Change its priority class
o Change its CPU affinity
o Enter High Performance power scheme
o Prevent PC sleep
o Terminate it (disallow)
o Keep it running (auto-restart)
o Limit the number of instances of that process
o Enter Gaming mode
o Restart or terminate if memory or CPU use exceeds a threshold (new in v3.99)
o And more!
* Unique system responsiveness graph
* Differentiate between svchost.exe instances
* Extremely low resource use
* Stand-alone process management engine (uses as little as 1MB of RAM)
* Gaming mode
* Both 32-bit and 64-bit builds for maximum efficiency
* Event logging
* MUCH more...
Process Lasso is written in native C++, not .NET. The background core engine that manages processes is completely independent from the graphical user interface, allowing you to keep process rules applied with almost no overhead. With Process Lasso, load time is instant and resource consumption is minimal.
https://www.ryanvm.net/forum/viewtopic.php?t=9383Last edited by gor17981; August 31st, 2011 at 12:59 PM.
Taskbar Shuffle v2.5 x86 and x64 silent installers
By razorsedge in forum TaskbarReplies: 1Last Post: January 1st, 2013, 07:12 PM -
video4pc silent installers
By razorsedge in forum Internet File Management AppsReplies: 0Last Post: July 30th, 2012, 07:33 AM -
Unlocker 1.9.1x86 x64 silent installers
By razorsedge in forum Unlockers and renamersReplies: 2Last Post: April 16th, 2011, 02:02 AM -
Ultra Defrag silent installers
By razorsedge in forum Hard Drive ToolsReplies: 0Last Post: August 1st, 2010, 07:38 AM -
Explorer++ - Version 1.1 x86 & x64 silent installers
By razorsedge in forum Windows tweaking and Management AppsReplies: 0Last Post: August 1st, 2010, 02:20 AM
Windows 12
