August 5th, 2010 09:50 AM #1
Driver Fusion (Driver Sweeper) silent installer
Attachment 34725
*Crap Removed*
Author: Phyxion.Net https://phyxion.net/
License: Freeware
Requires: Win All
Driver Sweeper allows you to remove driver leftovers from your system. It's very important to remove your drivers on a proper way, because driver leftovers can cause problems like stability and startup problems. You can use it if you want to update/remove drivers from your system.
How to use ?
There are two methods to use Driver Sweeper.
Both methods achieve the same results. The first method is always able to clean all files:
1-Use the official uninstaller(s) of the driver(s) you want to uninstall.
Reboot your PC in Safe Mode.
Use Driver Sweeper and select what to clean.
Press the clean button.
This method will delete remaining files upon reboot (if deleting failed).
2-Use the official uninstaller(s) of the driver(s) you want to uninstall.
Reboot your PC.
You can add items by pressing the name of the driver you want to clean and then the ">" button, or to double click on the driver name.
You can remove items the same way, but then press the "" button.
More drivers can be selected for the same cleaning process.
What can it be used for ?
The current supported drivers are NVIDIA (Display and Chipset), ATI (Display), Creative (Sound) Realtek (Sound), Ageia (PhysX) and Microsoft (Mouse).
All the settings are saved in an ini file. Nothing is created in the registry, so it's possible to use it as a portable program. Log files can be saved to the harddisk and viewed as well. You can find the logs under the Tools menu.
https://www.ryanvm.net/forum/viewtopic.php?t=7431Last edited by gor17981; August 30th, 2011 at 10:13 PM.
Driver Signature Enforcement Overrider silent installer
By razorsedge in forum Driver relatedReplies: 5Last Post: January 11th, 2013, 04:17 AM -
Intel Rapid Storage Technology Driver silent installer
By razorsedge in forum Driver relatedReplies: 0Last Post: August 4th, 2012, 01:14 AM -
Universal ASIO Driver For WDM Audio 2.10 silent installer
By razorsedge in forum Driver relatedReplies: 0Last Post: July 22nd, 2012, 08:07 AM -
Driver Magician Lite silent installer
By razorsedge in forum Driver relatedReplies: 9Last Post: October 10th, 2011, 05:24 AM -
ATI Catalyst Driver Suite 10.8 Full silent installer
By razorsedge in forum Hardware/DriversReplies: 0Last Post: August 26th, 2010, 04:00 PM
Theme request
