August 6th, 2010 11:31 PM #1
RocketDock silent installer to have theme and icons default
Hi all
I have seen that many of you on here like to make rocketdock themes and so fourth to add with your themes or just stand alones.
This tut will show you how to create a rocket dock silent installer so when you install rocket dock it will come up with your theme and icons as well as screen placement settings and so forth on install.
What you need:
- Installed working RocketDock on your Windows
- Installed WinRAR
1. Install RocketDock, and customize it to your needs (with your icons, skins and everything) to look like your choice of default on screen. In RocketDocks settings be sure to click save as portable.ini so the settings are saved. Then open Windows Explorer and navigate to Program Files --> RocketDock. Click the folder in the left Window pane to display it's contents in the right Window pane. Perform a Ctrl+A to select all of the files displayed (all and only files installed into Program files/RocketDock folder. Right-click on the selection and choose "WinRAR --> Add to archive..."
2. Give the archive a name, something other than "RocketDock" since WinRAR will protest - for example RocketD. Don't worry, you can rename it later. Put a check in "Create SFX archive" to be .exe file and choose a compression method ("Best"). Notice that the archive is now configured to operate as an executable (.exe) file.
3. Now click the Comment tab and paste the following into the "Enter a comment manually" field:
Path=RocketDock
SavePath
Silent=1
Overwrite=1
Shortcut=P, "%programfiles%\RocketDock\RocketDock.exe", "RocketDock", "A convenient and fun way to organize your desktop icons.", "RocketDock"
You can Use the New EXE as the Silent EXE to install RocketDock to any machine. It will create the Shortcut in Accessories.
In pictures (everything is made in WinRAR):
Attachment 34956
Attachment 34957
Attachment 34958
Attachment 34959
Attachment 34960Last edited by Big V; August 18th, 2011 at 04:27 AM.
Rocketdock 1.35 silent installer
By razorsedge in forum RocketdockReplies: 7Last Post: September 27th, 2022, 04:22 PM -
Universal Theme Patcher 1.5 silent installer x86 & x64
By razorsedge in forum Theme PatchersReplies: 18Last Post: April 13th, 2020, 07:43 PM -
Changing Hud Machine Blue Theme Icons Back To Default Windows Icons?
By darkdream787 in forum IconsReplies: 1Last Post: April 22nd, 2014, 12:07 AM -
How to restore icons to default
By johnsmith2020 in forum IconsReplies: 3Last Post: January 14th, 2010, 04:32 PM
New app being released on W12, a tool that watches everything you do on your computer (Recall) - https://www.independent.co.uk/tech/microsoft-recall-ai-artificial-intelligence-b2548688.html
Windows 12
