Thread: NTREGOPT NT Registry Optimizer
August 8th, 2010 06:24 AM #1
Introduction
The registry files in an NT-based system
can become fragmented over time, occupying more space on your hard
disk than necessary and decreasing overall performance. You should
use the NTREGOPT utility regularly, but especially after installing
or uninstalling a program, to minimize the size of the registry files
and optimize registry access.
The program works by recreating each registry hive "from scratch",
thus removing any slack space that may be left from previously
modified or deleted keys.
Note that the program does NOT change the contents of the registry in
any way, nor does it physically defrag the registry files on the drive
(as the PageDefrag program from SysInternals does). The optimization
done by NTREGOPT is simply compacting the registry hives to the
minimum size possible.
ERUNT and NTREGOPT in their current versions 1.1j are still compatible with Windows 7, but as in Vista, they will only work correctly if you turn off User Account Control in Windows' Control Panel (move the slider to the lowest position).
[dl:1bw5jkm8]https://www.derfisch.de/lars/ntregopt-setup.exe[/dl:1bw5jkm8]
Need Help Fixing a Registry Setting
By Nimbi in forum Help & Support, RequestsReplies: 2Last Post: March 25th, 2019, 04:49 AM -
Windows 8 registry Tweaks
By razorsedge in forum Help and SupportReplies: 0Last Post: December 8th, 2012, 11:55 PM -
SpeedGuide.net TCP Optimizer 3.0.7 silent installer
By razorsedge in forum Internet\NetworkReplies: 0Last Post: July 22nd, 2012, 07:48 AM -
How To Delete Windows 7 Product Key From Registry
By razorsedge in forum General TutorialsReplies: 0Last Post: December 11th, 2010, 12:01 AM -
BP Internet Optimizer
By razorsedge in forum Internet\NetworkReplies: 0Last Post: September 27th, 2010, 02:17 AM
I did apply the stylehack.
Custom Class Maps and...
