August 9th, 2010 05:25 AM #1
How to Remove Shutdown Button from Windows Vista and 7 Login
Here we start the tutorial:
1. First take ownership of "%windir%\System32\authui.dll" file and then open it in Resource Hacker.
Note: here %windir% represents "Windows" directory which can be found in the system drive where Windows is installed. In most of the cases its C:\Windows.
2. Now press "Ctrl+F" keys or select "Find Text" option from "View" menu.
3. Type Shutdown in Find what text box. Click on "Find Next" button and it'll go to following lines:
Code:<element id="atom(ShutDownFrame)" layout="flowlayout()"> <button id="atom(ShutDown)" accname="resstr(12128)" tooltip="true"/> <button id="atom(ShutDownOptions)" accname="resstr(12131)" accdesc="resstr(12131)" tooltip="true" shortcut="115"/>
Code:<element id="atom(ShutDownFrame)" layout="flowlayout()"> <button id="atom(ShutDown)" accname="resstr(12128)" tooltip="true" layoutpos="none"/> <button id="atom(ShutDownOptions)" accname="resstr(12131)" accdesc="resstr(12131)" tooltip="true" shortcut="115" layoutpos="none"/>
5. That's it, click on "Compile Script" button and save the file. Now you'll not see the "Shutdown" button on login screen.
PS: Windows Vista "authui.dll" file contains only a single instance of (ShutDown) string, so you'll need to replace it only once using Step 3 and 4 but Windows 7 contains 3 instances of this string, so you'll need to change all the 3 instances in the file.
shutdown button
By Giova_7 in forum Start MenuReplies: 8Last Post: September 27th, 2015, 06:51 PM -
Remove/Change Colour of red close button on windows 8.1 Surface Pro 3?
By jayarte in forum Help and SupportReplies: 2Last Post: July 29th, 2015, 02:10 PM -
Remove/Hide Start Button
By Mbrys331 in forum DesktopReplies: 0Last Post: August 25th, 2012, 11:54 PM -
shutdown button not working after 7tsp
By MOST_WASTED in forum Theme IssuesReplies: 26Last Post: August 2nd, 2012, 08:35 AM -
Vista Hex-Edit Tutorial - For Windows VISTA
By Mr GRiM in forum MiscellaneousReplies: 2Last Post: December 30th, 2009, 06:40 PM
DWMBlurGlass App for...
