Results 7 to 12 of 37
Thread: VIRTUAL CUSTOMS
August 10th, 2010 08:42 AM #1
- Feb 2010
- Los Angeles, California.
- 1,702
- 10 Post(s)
VIRTUAL CUSTOMS
Proudly present my theme VIRTUAL CUSTOMS this theme has been major updated and aside from the task bar and frames everything was remade I hope you like it! P.S. I ike to thank big v and especially nofx1994 he helped me quite a bit also like to thank mr.grim and hacktheplanet and greenex and the maker of the sound pack and Scrollbars for all glass themes by OctogunSalata
https://octogunsalata.deviantart.com/art ... -160839103
and anyone else i may of forgot really thank you all i would have not got this theme the way i wanted if it wasn't for you so thanks so very much!Now for what the theme Includes:
Shell32 Replacement Images
Start Menu User Pic Frame
Windows Theme Installer
Black Glass Enhanced
explorerframe.dlIncludes:
explorerframe.dll
5 System Icons by mr.grim
4X Wallpapers by nofx1994 thanks bro!
Cursors by mauam (Pre-Installed)My thanks!
Fonts. (Install prior to theme installation.)
Attachment 42103
Attachment 42010
ENJOY...
~A n d - P l e a s e - D o n t - S t e a l - M y - W o r k~
_______________________________________________________________
License Agreement: This content is protected by DMCA. (Digital Millennium Copyright Act Protection Services) Last edited by bigcyco1; December 7th, 2014 at 10:48 AM. Reason: Updated fix a few bugs.
[SIGPIC][/SIGPIC]
February 21st, 2011 07:42 PM #7
- Feb 2011
- 24
Re: VIRTUAL CUSTOMS
hallo bigcyco,
thank you for your answer, i will try to get advice from nofx1994.
What i want is to change this boring taskbar in the default aero of win 7. its only a line without nothing. what me inspired is the creative looking of your line and i saw others here in the forum.
so, what i did first, i just copied the tow images 899 and 900 from the msstyle file with restorator. than i changed the 899 bitmap with a view filters in xnview. and what i believe, you have to put more images together to get a wonderfull line. ok, what i first wanted to know is, how can you make it possible to see this newly created image in your taskbar. i tried to assign it in restorator back, but nothing happens after saving the new msstyle and restart the system. there must be other files relevant for this. have you any advice ?
thank you very much, if you have more tips about that, just put yout answer here, if you have time.
February 21st, 2011 10:37 PM #8
- Feb 2010
- 1,702
- 10 Post(s)
Re: VIRTUAL CUSTOMS
Originally Posted by [url=https://virtualcustoms.net/viewtopic.php?p=32445#p32445
first test your theme in windows style builder or vista style builder which ever you have if it works then OK. Now save it to your desktop. Rename it to whatever you want to. Create a new folder on your desktop, and give it the same name. Open that folder and create another new folder inside that one. Rename it also to the same name. (Make sure that the name is exactly the same!)
Now paste your .msstyle file into the second folder you created.
Copy one of your existing themes's .theme file and paste it into the first folder you renamed. Rename that to your themes name. Open that .theme file with notepad (Right click and open with notepad) Inside the notepad file you will see places with the original themes name. All those names you have to change to your themes name. Exactly the same. Save it. In there you will also see paths to your cursors and wallpapers. Take note of these. You now have to open the second folder you created. (The one with your .msstyle file inside.) in here create a wallpaper folder (Make sure it has the same name as inside your .theme file. Take the en-US folder as well as the Shell folder from the same theme you took the .theme file. Open the en-US folder and rename the .msstyles.mui in there to the same name as your themes name. Remember that the file extensions must remain at the back. Save. The Shell folder you can leave the same.
So on your desktop you will now have a folder that says (I will just give it a name) Blue Gloom. When you open this folder you will have another folder that says Blue Gloom. Also you will have your Blue Gloom.theme file there. Open the Blue Gloom folder. In there you will have a wallpaper folder (With your wallpapers inside. Names the same as what it is in the Blue Gloom.theme file.) You will have your Blue Gloom.msstyle file, the en-US and Shell folders.
Double check that all your names are 100% the same everywhere. (The theme will not work if just one error!) Check that all the names in the Blue Gloom.theme file is Blue Gloom, and that the paths to your wallpapers are correct and that the names are the same as in the wallpaper folder.
Done. Now paste the Blue Gloom.theme file and the Blue Gloom folder into your C:\Windows\Resources\Themes folder and check it!
__________________[SIGPIC][/SIGPIC]
February 22nd, 2011 04:55 PM #9
- Feb 2011
- 24
Re: VIRTUAL CUSTOMS
ok, thank you very much again for your reply. i tried this yesterday what you explained me , but forgot to edit the .theme file to change it :grim: how stupid from me. well allright i will try it again later and hope all goes well. first i read the topics again which you adviced me. i am sure i will post again here. till there, see you later
February 24th, 2011 06:07 AM #10
- Feb 2010
- 1,702
- 10 Post(s)
Re: VIRTUAL CUSTOMS
Originally Posted by [url=https://www.virtualcustoms.net/viewtopic.php?p=32567#p32567[SIGPIC][/SIGPIC]
March 5th, 2011 10:58 AM #11
- Feb 2011
- 24
Re: VIRTUAL CUSTOMS
hallo again,
meanwhile i was able to use my own theme in the way described. the only thing is, that the theme crashes the desktop windows manager DWM, if i start the theme automatically with windows. if i load it, when my system is started yet, there are no problems. i tried this with windows 7 32bit and 64bit.
i resized all images in the DWM section of WSB to their original sites to avoid problems from this site. perhaps the taskbar image has too much colours in it and for that you cannot use it in aeromode,
any advice, would be glad, to hear from you.
i send the taskbar image as an add
March 6th, 2011 12:03 AM #12
- Feb 2010
- 1,702
- 10 Post(s)
Re: VIRTUAL CUSTOMS
Originally Posted by [url=https://virtualcustoms.net/viewtopic.php?p=33601#p33601[SIGPIC][/SIGPIC]
Virtual Customs
By poweredbyostx in forum Log On ScreensReplies: 3Last Post: September 10th, 2013, 11:37 AM -
Virtual Customs Customs Design
By MrToxicCodes in forum General Windows 7 CustomizationReplies: 3Last Post: July 18th, 2012, 05:51 AM -
Hello Virtual Customs
By robj2005 in forum Welcome to Virtual CustomsReplies: 11Last Post: June 8th, 2012, 03:37 PM -
Hi Virtual Customs
By OrangePillow in forum Welcome to Virtual CustomsReplies: 13Last Post: November 1st, 2011, 06:14 PM -
virtual customs
By The Archiver in forum Wallpapers Posted by The ArchiverReplies: 11Last Post: October 20th, 2011, 04:43 PM
Miscellaneous Music...
