August 13th, 2010 03:46 AM #1
How to Rename “Favorites”, “Libraries”, “Homegroup”, “Comput
How to rename these items present in Navigation pane. By default, Windows only allows you to rename "Computer" item. You can right-click on it and select "Rename" and type whatever name you want to give.
But what about other items? You can rename them too using a simple registry trick which is mentioned in the coming steps.
Attachment 35400
We'll modify the same registry keys which we modified in the above mentioned tutorials to remove the items. We'll just edit a String value "LocalizedString" for each Navigation pane item and give it our desired name.
So without wasting any time, lets start the tutorial:
1. Type regedit in RUN or startmenu search box and press Enter. It'll open Registry Editor.
2. Now go to any of following keys according to your requirements:
Code:Favorites - HKEY_CLASSES_ROOT\CLSID\{323CA680-C24D-4099-B94D-446DD2D7249E} Libraries - HKEY_CLASSES_ROOT\CLSID\{031E4825-7B94-4dc3-B131-E946B44C8DD5} Homegroup - HKEY_CLASSES_ROOT\CLSID\{B4FB3F98-C1EA-428d-A78A-D1F5659CBA93} Network - HKEY_CLASSES_ROOT\CLSID\{F02C1A0D-BE21-4350-88B0-7367FC96EF3C}
You can use following simple steps to take permission:
* Right-click on the key mentioned in Step 2 and select "Permissions...".
* It'll open a dialog box, Click on "Advanced" button.
* It'll open another dialog box, Go to "Owner" tab.
* Select your Username from the list and click on "Apply" button and then OK.
* Again click on OK button in the first dialog box.
* Now again right-click on the same key and select "Permissions...".
* Select your Username in the list and check the "Allow" option for "Full Control".
* Click on Apply button and then OK.
4. Now double-click on "LocalizedString" String value given in right-side section and change its value to any desired name like "PC Favorites", "My Libraries", "Home Network", etc.
5. That's it. Now open My Computer and you'll see the new names for each item.
NOTE: If you want to restore the default names, you can use following default values of "LocalizedString" String value:
Code:Favorites - @%SystemRoot%\system32\shell32.dll,-21796 Libraries - @%SystemRoot%\system32\shell32.dll,-50691 Homegroup - @%SystemRoot%\system32\shell32.dll,-50688 Network - @%systemroot%\system32\NetworkExplorer.dll,-1
Is it possible to colorize homegroup??
By faizalotai in forum Theme Building QuestionsReplies: 0Last Post: October 17th, 2011, 03:43 AM -
[How To] Change the Homegroup Background
By Mr GRiM in forum Windows Style Builder v1.5 TutorialsReplies: 4Last Post: September 9th, 2011, 07:34 AM -
IE8 Favorites Panel Header Color
By siemprelisto in forum Firefox\IEReplies: 0Last Post: September 15th, 2010, 11:54 PM -
Changing the 'Libraries' and 'Favorites' icon on Windows Exp
By Pickaxe in forum IconsReplies: 7Last Post: February 9th, 2010, 04:17 AM
Hello world, I am...
