August 21st, 2010 03:49 PM #1
What is Windows Kernel Mode Power Manager?
Windows uses power management technology to reduce power consumption for PCs in general and for battery-powered laptops in particular. For example, a Windows computer can be put in a sleep or hibernation state.
A complex power management system for computer devices has evolved so that when the computer begins to shut down or go to lower power consumption, the attached devices can also be powered down in a proper manner so that no data is lost.
But these devices need a warning that the power status in changing and they may also need to be part of a communications loop that tells the controlling device to wait until they can shut down down properly.
The Windows kernel-mode power manager manages the orderly change in power status for all devices that support power state changes. This is often done through a complex stack of devices controlling other devices. Each controlling device is called a node and must have a driver that can handle the communication of power state changes up and down through a device stack.
If you are writing a driver that can be affected by power-state changes, you must be able to process the following types of information in your driver code:
* System activity level.
* System battery level.
* Current requests to shut down, sleep, or hibernate.
* User actions such as pressing a power button.
* Control panel settings, such as automatically shutting down at 10 percent battery power.
For details visit: https://msdn.microsoft.com/en-us/libr...8VS.85%29.aspx
Windows 10 Dark mode mode Ribbon
By ceo54 in forum Windows 10 Theme Help and SupportReplies: 6Last Post: March 1st, 2021, 05:07 PM -
How to tell if Windows 8.1 runs in UEFI mode or in the Legacy BIOS mode
By Originalganjaman in forum General TutorialsReplies: 0Last Post: February 3rd, 2014, 12:34 PM -
Windows Kernel event ID 41 error – System has rebooted witho
By razorsedge in forum News & ReviewsReplies: 0Last Post: October 18th, 2010, 09:39 PM -
TDL3, the first Windows x64 compatible kernel mode rootkit i
By razorsedge in forum News & ReviewsReplies: 0Last Post: October 16th, 2010, 09:50 PM
DWMBlurGlass App for...
