August 21st, 2010 04:01 PM #1
Theme Manager - Windows 7 by ~bickelk
Attachment 35621
Theme Manager allows you to install, apply, and remove themes all from one location. Support for screenshots is also included so you can view themes before applying them.
Current Verison = 1.1.2
All versions support 64-bit Windows.
Version 1.1.2 and higher support 32-bit Windows.
YOUR SYSTEM FILES MUST BE PATCHED BEFORE USING THIS APPLICATION!
I recommend "UxStyle Core" for that. Here is the [link]
How to use Theme Manager:
Installing themes:
Check the boxes for all the theme components that are included. Browse to each file and click "Install Theme". The theme will be added to the list on the right
Applying a theme:
Select the desired theme in the theme list and click "Apply Theme". The screen may flash a few times while loading the theme.
Removing a theme:
Select the desired theme in the theme list and click "Remove Theme". You cannot remove the currently applied theme.
Restoring Windows Defaults:
Select the "Aero" theme in the theme list and click "Apply Theme".
Reseting Theme Manager:
Note: This removes all installed themes and applys the Windows Defaults.
While in Theme Manager press the "R" key on your keyboard. Select "Yes" on the pop-up warning.
Export a theme as a Zip file:
Select the desired theme in the theme list. Press the "E" key on your keyboard. The Zip file will be created on your Desktop.
View or Take screenshot:
Press the Expend key (the long button on the very right side) to open the screenshot pane. If a theme is selected its screenshot will show.
To take a screenshot, Apply the theme and with its name selected press the button below the screenshot viewing area.
Double clicking on a screenshot will expand it to see more detail.
The first theme you apply will automatically require a system restart. After that only themes that change the current shell32.dll or OobeFldr.dll in place will require a system restart to fully apply. Anything else is applied immediately with no restart required.
Task Manager Windows 11 22h2
By tistou77 in forum Help & Support, RequestsReplies: 7Last Post: May 1st, 2024, 02:06 PM -
Need the task manager skin for the windows 8.1 version of the theme A Thin White Line
By Nimbi in forum RequestsReplies: 2Last Post: September 24th, 2014, 03:36 PM -
7-Zip Theme Manager
By _Deano_ in forum Tweaking and TuningReplies: 3Last Post: July 24th, 2011, 05:09 PM -
Issue with Theme Resource Manager
By hellfirefox in forum System properties\OrbReplies: 12Last Post: June 19th, 2011, 07:59 PM -
Customized Task Manager for Windows 7
By razorsedge in forum MiscellaneousReplies: 0Last Post: December 10th, 2010, 11:42 PM
https://virtualcustoms.net/showthread.php/86740-SecureUxTheme-patcher-Support-for-Windows-11
Animation in explorer...
