August 23rd, 2010 01:11 PM #1
Clear the Windows Paging File at Shutdown, the Microsoft way
While one can always use our Ultimate Windows Tweaker to set Windows to delete the Page File on every shutdown easily, you can also use a Fix It released by Microsoft. Cleaning the page-file on every shutdown means overwriting the data by zeros, and it takes time. This will increase shutdown time.
msfixit Clear the Windows Paging File at Shutdown, the Microsoft way!
But if you work on confidential documents, then you may want to have this setting ‘on’. When you load such documents, they are loaded into RAM. To save RAM Windows places certain items in the page file. Hence you may want to delete page file at every shutdown, in such cases.
Some third-party programs can temporarily store unencrypted (plain-text) passwords or other sensitive information in memory. Because of the Windows virtual memory architecture, this information can be present in the paging file.
Although clearing the paging file is not a suitable substitute for physical security of a computer, you might want to do this to increase the security of data on a computer while Windows is not running.
Running this Microsoft Fix It available at KB314834 https://support.microsoft.com/kb/314834, clears the Windows paging file (Pagefile.sys) during the shutdown process, so that no unsecured data is contained in the paging file when the shutdown process is complete.
If you want you can also clear the paging file manually! To do so open regedit and navigate to the following key:
HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Control\Session Manager\
Right-click on Memory Management and select New > DWORD (32-bit) Value.
Name the DWORD value ClearPageFileAtShutdown.
Double-click on the DWORD value and type 1, in the value data box.
That’s it! To reverse the process, type 0 (zero) in the value box instead!
Windows shutdown dialog icon
By innuendo in forum General Windows 10 CustomizationReplies: 1Last Post: February 10th, 2020, 04:17 PM -
How To Add Shutdown Tile To Start Screen In Windows 8
By razorsedge in forum Help and SupportReplies: 0Last Post: December 8th, 2012, 03:23 AM -
clean pagefile at shutdown Microsoft Fixit 50463
By razorsedge in forum Windows tweaking and Management AppsReplies: 0Last Post: July 22nd, 2012, 05:42 AM -
Microsoft Releases Update to Fix Unexpected Shutdown or Blue
By razorsedge in forum News & ReviewsReplies: 0Last Post: September 29th, 2010, 11:08 PM -
How To Clear The Windows Paging File At Shutdown
By razorsedge in forum Setup TutorialsReplies: 0Last Post: August 31st, 2010, 08:59 PM
Windows 12
