Results 19 to 24 of 25
September 4th, 2010 06:04 PM #1
Token V2 Icon Pack With Installer
by Mr-Ragnarok.
This will only work for WIN7 BUILD 7600 X64 (64bit).
There is NO folderband (the panel with organize, share etc)
So make all the changes commited to that panel before U install cause that option will be gone after install. Its no big deal if U forget cause U can always run a normal installer to get it back.
The installer is very detailed with all the little things.
It will also change the startup sound and logon screen.
Attachment 36510
Attachment 36509Last edited by Big V; September 1st, 2011 at 11:41 PM.
November 5th, 2014 05:42 AM #19
- Jun 2014
- India
- 49
- 108 Thread(s)
Dear friend,
Please use restorator or a similar application to change the icons for the programs you wish to, and the same will reflect on the taskbar. That's how I do it.
For others, if there is an easier way to do it, please let us know.
Cheers,
AC
November 5th, 2014 06:31 AM #20Last edited by idle; November 5th, 2014 at 06:35 AM. Reason: Added MyPc image for light/dark contrasts
November 5th, 2014 12:17 PM #21
November 5th, 2014 12:41 PM #22https://pul53dr1v3r.deviantart.com/ar...eter-444287665 There you got mate.
Does anyone know how to play around/remake Rainmeter skins? I found an awesome skin https://j22fish15.deviantart.com/art/...eter-472694537 that I desperately need working, but it doesn't fit my screen. I have a 17" laptop 1920x1080If your desktop is under 1080 pixels wide, this skin will not fit.
Anyway, if someone can help
November 5th, 2014 03:43 PM #23
- Jun 2014
- India
- 49
- 108 Thread(s)
Dear friend,
My two cents:
Your desktop has a width of 1080 already. So, I'm not sure as to why it won't fit perfectly. I downloaded the skin, and checked the config file. you will need to undo any initialization (currently, values are initialized and invoked as and when required during the program), and give it your own values. You can also reposition the icons on the bar by giving the x and y coordinates whatever values you want, and it think it happens best through trial and error. Points to remember:
1. Anything arranged horizontally will have the same 'y' coordinates.
2. Anything arranged vertically will have the same 'x' coordinates.
It's quite simple and straightforward actually. Also, try the following:
1. Click on the link
2. Go through the rainmeter tutorials there; they're really useful.
3. Apply the same learning to the skins that you wish to tweak
I would advise that you spend some time figuring this out for yourself mainly because you would not need to depend on anyone to tweak things out for you, thereby reducing your waiting lead time, and making you more proficient, independent and self-sufficient going forward.
I have no technical skills whatsoever, and if I could figure it out, I'm sure you'll do wonders
Cheers,
ACLast edited by Craniumshatter; November 5th, 2014 at 03:45 PM.
November 5th, 2014 05:18 PM #24
- 1,575
There is no reason to use software to change your taskbar icons, especially 7 conifer, which if memory serve me right comes with adware / malware bundled.
There is a way to do it manually without any software whatsoever.
The pdf attached is the from How To Geek site, a webpage I converted to pdf for reference when needed, the tutorial is for Windows 7 but applies to 8 and 8.1 also.
Windows 10 Token Light Icon Pack
By gsw953 in forum 7tsp Icon PacksReplies: 126Last Post: April 30th, 2022, 11:01 AM -
7tsp Windows 10 Token Light Icon Pack v2 w10 19h1-21h2
By ミறѳѳղղįզվદ彡 in forum Themes by gsw953Replies: 1Last Post: March 14th, 2022, 04:17 PM -
Missing Token Icon Pack
By 2635599 in forum General Windows 8 CustomizationReplies: 3Last Post: May 21st, 2014, 12:59 AM -
Icon Pack Installer
By x0xPhantomx0x in forum RequestsReplies: 0Last Post: June 29th, 2012, 08:02 PM -
Mac os leo Icon Pack installer X86
By dokumaci in forum Custom IconsReplies: 0Last Post: July 25th, 2010, 01:53 PM
Thank you:happy::happy:
Office 16 64-bit Color...
