September 16th, 2010 09:42 PM #1
Windows Installer folder : To delete, or not to delete; that
Over a period of time, as and when you install and uninstall programs on your Windows computer, you may find your Windows Installer folder growing bigger and bigger and could run into several gigabytes too!
The Windows Installer folder is a hidden system folder situated in C:\Windows\Installer. To see it you have to through Folder Options, uncheck the Hide protected operating system files option.
If you open the folder you will see a lot of Installer files, and folders containing more Installer files.
Attachment 36794
Whenever you install a program using the Windows Installer, a copy of changed system information is placed in this folder. The folder contains the saved copies of the installed updates that are applied by the Installer. This information is required, if you decide to uninstall the program. Most of the times, it wont be complete files – it could just be the size of the triggering msi. If you delete the particular folder, or its contents, you may not be able to uninstall or repair the program using the Windows Installer.
You may at some point of time, face a situation where you find that that your system drive is running out of space and this folder is occupying a lot of space.
A question most ask is: Is it safe to delete the Windows Installer folder or its contents?
Well if you empty the folder, your system would still continue to operate normally. But as mentioned, should you at any point of time decide to uninstall/repair/update a program, you would not be able to do so!
Therefore, you should not delete files from the Installer folder; atleast not manually, as this folder is a cache for installation files and patches (MSP files) and removing these will not let you uninstall or repair programs. Furthermore, it may even prevent you from applying or removing, updates or patches to software.
However if you are really hard-pressed to create more space on you system drive, you may try and cut-paste its contents to another drive for safe-keeping.
Alternatively, you may try and clean out the Installer folder by downloading Windows Installer Cleanup Utility and then running the command:
msizap.exe g!
When you run this command, the installer & patch packages are enumerated. The unreferenced packages are considered to be safe to be deleted. The “g” option removes, for all users, any cached Windows Installer data files that have been orphaned.
Msizap.exe https://msdn.microsoft.com/en-us/library/aa370523.aspx is a command line utility that removes either all Windows Installer information for a product or all products installed on a computer.
However, products installed by the installer may fail to function after using Msizap and it may and may move the machine to an inconsistent state. As a result, Microsoft has stopped support for the Windows Installer Clean Up utilityLast edited by Big V; August 12th, 2011 at 04:42 AM.
How to Delete the Windows.old folder
By peter.pan in forum ExplorerReplies: 1Last Post: December 4th, 2012, 05:26 AM -
Delete your rescache in Windows 7 so it easier to apply mods
By razorsedge in forum Windows 7 Theme Help & SupportReplies: 7Last Post: June 2nd, 2012, 08:57 PM -
How To Delete Windows 7 Product Key From Registry
By razorsedge in forum General TutorialsReplies: 0Last Post: December 11th, 2010, 12:01 AM -
Add Copy, Paste and Delete Buttons to Windows 7 Explorer too
By razorsedge in forum General TutorialsReplies: 0Last Post: December 10th, 2010, 11:26 PM -
How to delete EVEN the Flash Cookies in Windows!
By razorsedge in forum System, Junk, Reg CleanersReplies: 0Last Post: October 5th, 2010, 04:05 AM
